      05-26-2014, 02:19 PM   #1
Joyaant911
Drives: 2007 x5
Help with tire sizes for 22"
Ok I need major help. I set up my new 22" wheels but I'm running the wrong tires being that I had no money for tires strait up! I'm tuning 265-30-22 and 295 25 22 front and rear. Car has a 1.2" drop. Now big question I was thinking of changin the rear tires to 305 35 22 and leaving the fronts as is.. Anybody have experience dealing with this I know the sidewal height will be totally different and it could cause problems just need to know if it's possible without damaging anything or would I also need to change the front tires as well...
      05-26-2014, 02:54 PM   #2
///SAL
///SAL's Avatar
Drives: 2014 ///M5 ZCP
22!!!!! Damn plz post pics when your done. I hope your not planning to have ppl sit in this car.
      05-26-2014, 03:28 PM   #3
Joyaant911
Drives: 2007 x5
Car looks more dropped than it is.
      05-26-2014, 07:12 PM   #4
mitch808
Drives: 2012 X5 35i
If you were to run a staggered setup, your wheels should be wider in the rear like a 22x11 in the rear and 22x10 up front or similar. You just stated 22", not the width, are these staggered or not?
If you kept the 265/35/22 and added in the rear 305/25/22, now we're talking.... That's only within 1MPH difference front and rear.
Doing a 305/30/22 would be a 4MPH different and may cause you issues with your trans/diff.
      05-26-2014, 07:14 PM   #5
Joyaant911
Drives: 2007 x5
22x9 and 22x10.5 running 265 30 and 295 25.. So doing that swap would cause issues unless I change my fronts to 35 and do 30 on the rear. Could I do35 all around staggered?
      05-28-2014, 11:10 AM   #6
Joyaant911
Drives: 2007 x5
Any input?
      05-28-2014, 12:21 PM   #7
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
35 profile all around, but with staggered widths? No way.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
      05-28-2014, 07:07 PM   #8
Joyaant911
Drives: 2007 x5
Can anybody gimme inputs on correct sizes that can be run?
      05-29-2014, 05:43 AM   #9
upstate650
upstate650's Avatar
Call tire rack and see what they can recommend.
      05-29-2014, 09:45 AM   #10
Joyaant911
Drives: 2007 x5
They didn't even give me a recommendation on 22's
      06-02-2014, 06:28 PM   #11
BMWOO7
BMW CCA #505303
BMWOO7's Avatar
Drives: 2015 X5M / 2013 SVT Raptor
I was going to say the same thing, try Tire Rack.
What I like to do is find the tire your looking for, then go to the 'specs' tab or section and see what the diameter is or the 'revs per mile'.
I think factory standard, at least from what I've seen is a difference of like 7-10 revs per mile and about .3"-.5" difference in outer diameter (OD).
So you'll usually see like a 35 series up front and then a 30 series in the rear.
I'm not that familiar with tires that large (22") so I don't know that I could help ya more than that.
The only other thing I'd do is contact several of these tire and wheel places that sell these 22" or 24" wheels and see what they recommend for something like this.
I'm guessing that your main concern is ensuring that the XDrive doesn't get messed up and still operates properly. With that said, you could try BMW to see if they could tell you what the max difference in tire size can/should be, but I don't know if they'd know past the factory OEM wheels and tires.
In either case, please post back with pictures and what you end up finding out!
2015 BMW X5M F85 ///M
      06-03-2014, 03:30 PM   #12
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
FYI, OE tires are perfectly matched front to rear.
http://www.tirerack.com/tires/tires....fore%2010%2F10
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      06-03-2014, 03:49 PM   #13
Z@T
Pilot
Z@T's Avatar
Drives: M3, Vantage, 997, ModelX
Depends on how wide the rims are.
Since the OEM 21" size is 325/30R21, I definitely would not get smaller since your car would look like rolling out of the hood.
Here a calculator to match similar tire sizes with the larger rims.
http://www.techcons.at/index.php/abrollumfangrechner
345/25R22 would be a close fit. 0.36% difference.
      06-06-2014, 12:48 PM   #14
iMore
iMore's Avatar
Drives: 2009 BMW X5 E70 3.0si Premium
...She's a beauty!
Pretty much identical to what I want mine to eventually look like. Quick question (off topic) - What type of exhaust are you running and what tips do you have installed? I really like that look.
Thanks
      06-06-2014, 09:25 PM   #15
Joyaant911
Drives: 2007 x5
Originally Posted by iMore View Post
...She's a beauty!
Thanks
Cherry bombs replace resonators than Xpipe to strait pipe to custom made tips. I bought some tips off eBay but they ended up being to big because of the Y attachment so he cut off the Y extension as basically created his own custom tip. Pm me I can send all links but you'll have to find somebody who can custom fit the tips.
EDIT.. Got new tires. Went with 265-35 and 295-30 rears are gonna have a 5mm spacer for alittle more flush sitting even with the 20 ET already
      07-10-2014, 06:52 PM   #16
PJB
New Zealand
Drives: X5M, CLS 55AMG Jensen Int
Back to the query re 22's my tyres are 295 and 335. Regards
PS Post #1 - hope it works !
      07-10-2014, 09:11 PM   #17
larryv
larryv's Avatar
64
Drives: 17 M3 ZCP 11X5 M Sport 20 I3
Looks nice, what wheels are those?
      07-13-2014, 05:52 PM   #18
PJB
New Zealand
Sorry for the delay - must confess don't actually know and wife and kids are off skiing with it so I can't make a physical check. Supplied by BMW dealer in Auckland. I could have had them or the standard ones, went big, what the hell !
      08-11-2014, 07:47 PM   #19
PJB
New Zealand
Finally the dealer advises ...
BMW300 M 22in copies
"The wheels are made by WSP Italy. They actually supply a lot of wheels to BMW, Audi etc so they’re basically factory wheels".
Yeah right - but a legit company at least !
Anyway very happy with them, the ride is great - better than the standard run flats 20's IMHO.
      06-29-2020, 06:38 PM   #20
Trickyd1609
X5 E70 convert
Trickyd1609's Avatar
Drives: X5 E70 2011
Hi there, im a first time poster here too so please accept my apologies if im crashing your post!
I have bought a set of AXE EX30's (9x22 front ET20/10.5x22 ET25 rear) in 22's but i think the tyres on them are wrong in terms of overall variation. I havent a clue how to calculate them so if you could help that would be great!
They have on:
Front 285 30 22 & Rear 315 30 22 but im thinking this rear should be 335/25?
Am i right in my thinking here? Also with this kind of offset ET20 front/ET25 rear does this work ok without any spacers? Ive seen that the offset should be ET40 front and ET30 rear? im not wanting an aggressive look and want to keep them within the arches on my Msport model X5
Chris
      06-29-2020, 07:22 PM   #21
95wildtt
Need mo $$s
95wildtt's Avatar
Drives: 2020 X4M Competition
Welcome.
Here are a couple of tools that may help you with your decisions...
Offset Calculator:
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
Tire Size Calculator:
https://www.tacomaworld.com/tirecalc...0r22-335-25r22
John
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan
1995 Dodge Stealth TwinTurbo
Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport
      06-30-2020, 03:44 AM   #22
Trickyd1609
X5 E70 convert
Drives: X5 E70 2011
Hi John, thank you for your reply and the calculators! they are fantastic.
It tells me on the calculator that my fronts on the AXE 22 wheels are now 5mm less on the inside to the strut and will need extending an extra 40mm on the outside edge of the new wheel to make it the same offset as my current 20's
the rear they are saying is 15mm less clearance on the inside and to extend 35mm
does this all sound correct? does this mean id need 35mm spacers rear and 40mm spacers front?
i dont know much about this so im hoping spacers like this wouldnt cause any extra wear and tear on other items on the car and be totally safe? if not ill just sell them and buy the correct offset next time!
