      07-08-2014, 06:29 PM   #1
aclockwrk
Drives: '15 M3 6spd
Whining / Whiring noise when revving and driving
I have an 08 X5 4.8i (129k miles) and for the past week or so I noticed a Whine /Whirring sound when revving the engine as well as driving. When driving you can hear it at lower speeds up to 40 or so, it still make the noise going faster its just harder to hear with wind and tire noise. sI took a video of it while it was in park while I revved it.
https://dl.dropboxusercontent.com/u/...08%20whine.mp4
It looks to like its coming from the passenger side front. I ordered a water pump thinking it was that but when I took off the serpentine belt and turnd the pump it was silent and it felt normal. I spun the idler pulleys too, seemed ok.
I thought about it some more and looked at the Vacuum pump also known as the air pump. I pulled the top hose off and noticed oil inside it. That general area seems to be loudest and possibly where the sound is coming from.
I know the pump is used for vacuum assist on the brakes and already had the brake booster cable recall done (precent oil from entering brake booster). They didn't touch the vacuum pump. I don't really see fresh oil near the pump but do see where it probably seemed from the hose. Possiby there is an internal seal leak on it.
Has anyone ever heard of this noise and have any more info, before I order a vacuum pump?
Thanks.
      07-09-2014, 06:03 PM   #2
nabizzy
Drives: 2018 X5M LBB
I had this noise in my M and it ended up being a leaking vacuum pump. But I would get it checked at the dealer if possible.
2018 BMW X5M (LBB)
2018 Audi R8 V10 Plus
2018 Ford Mustang GT350
2019 Audi Q8
      07-10-2014, 10:14 AM   #3
RichardH
RichardH's Avatar
South Africa
27
Drives: X5M
I also have a whining sound. Dealer tells me its the oil pump. Says its normal, but I don't agree. The link is not working
      07-11-2014, 08:53 AM   #4
MonacoJoe
Drives: X5M - Carbon Blk
this had been discussed quite a bit. mix success getting dealers to fix (replace oil pump). mine declined said it was "normal". yes normal for a chevy not a $100k bmw
      07-11-2014, 09:25 AM   #5
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
It's not causing any harm, but there is a TSB for the noisy oil pump.
I was able to get mine replaced under warranty a few months back, and it is much quieter now.
For me, the noise was most audible at low speeds at about 2k rpms.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      07-11-2014, 09:53 AM   #6
MonacoJoe
can you point us to the TSB?
      07-11-2014, 03:49 PM   #7
Draper
Draper's Avatar
3461
Not sure of the exact TSB, but here's the original thread I found right before I got mine replaced.
http://www.xbimmers.com/forums/showthread.php?t=850829
Also, here's the actual invoice from my replacement.
