09-16-2021, 11:27 AM | #1 |
Rep 214
If you were doing an A/B/C Del today....
Where would you turn to source your hard parts &/or for the tuning stuff?
I'm trying to pre plan so as to be ready when the day comes to pull the trigger on this vehicle configuration (which could be any day or not for a while). Thanks in advance
‘22 X2 S-Drive. Running 13mm Wheel Spacers & 255-wide 'go-flat' tires.
Former Owner '11 X5 35d w/Sport Package Former Owner '86 528 |
09-18-2021, 08:27 AM | #2 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
Find a good local shop that stands behind their work and use their recommended parts and tune, unless you plan to diy.
09-19-2021, 07:15 AM | #3 |
Rep 214
Was/am thinking about doing it myself.
10-01-2021, 06:10 PM | #6 | ||
Rep 201
EGR upper & lower block off kit, intercooler pipe seals, EGR race pipe. Vacuum hose, Crankcase hose You'll also need a lower EGR block off plate (doesn't come with vrsf pipe), swirl flap delete, intake seal kit. Also did glow plugs and controller. |
