08-28-2021, 03:36 PM | #1 |
Rep 108
Oil leak on front passengers side of motor
Hey all, I have an 11 35ixdrive and it has developed an oil leak on the passengers side of the motor on the front. It’s been pretty slow, a few drops on the ground when parked over night, but I want to try and fix it. I got under it today and I could see the water pump had a lot of oil on it so it has to be above that. I am thinking bad vanos seals? Any other ideas where to look? I know it’s not the valve cover because that is dry, but I’m not sure if there is anything else in that area other than vanos that could leak oil.
08-28-2021, 07:42 PM | #2 |
Rep 872
I had a leak in the same area turned out to be upper and lower oil pan (X5M). GL.
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
08-29-2021, 11:35 AM | #5 |
Rep 357
08-29-2021, 12:00 PM | #6 |
Rep 108
09-11-2021, 11:54 AM | #8 |
Rep 108
09-11-2021, 03:15 PM | #9 |
Rep 1,171
