Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Photo/Video/Media Gallery > N55 e92 Bad sound in the middle
      02-11-2024, 04:29 PM   #1
Mateusn55
Mateusn55's Avatar
Poland
Drives: Bmw e92 n55
Hi , what will be the problem . When the engine warms up , I hear this sound when I add gas . What could the problem be due to . Thank you for your reply
Engine: n55 e92
Link: https://youtube.com/shorts/IxhOE_Zxh...26EaWD1nYY4HPa
      02-12-2024, 07:30 AM   #2
whyzee125
Drives: Dinan stage 2 335i
Engine: n55 e92
Is it an auto or manual?
      02-12-2024, 01:02 PM   #3
Mateusn55
Mateusn55's Avatar
Poland
Drives: Bmw e92 n55
It is an auto
      02-13-2024, 05:06 AM   #4
Mateusn55
Mateusn55's Avatar
Poland
Drives: Bmw e92 n55
It is an auto
      02-13-2024, 07:08 AM   #5
whyzee125
Interesting. My first guess would've been throwout bearing.
Hard to say without putting a scope on it but likely something like the AC compressor or idler pulley. Could possibly be inside the engine or trans if it's coming from the middle of the car but I've noticed that sounds can be very deceiving on where they come from, especially on modern cars.
      02-26-2024, 11:05 AM   #6
Hoody007
Hoody007's Avatar
Drives: 335i ZMZ LCI | 850i/6
I have the same noise on mine - really noticeable in stop and go traffic. Though perhaps not as pronounced. Here’s what mine sounds like - same noise?
One shop said it was my motor mounts starting to go. For me it’s really localized to the passenger side. Thinking about changing the boost solenoid of all things, as those are known to go bad and make noise too. Will also say I’ve already had my rod bearings replaced (only like 10K miles ago, OE bearings). Car boosts & drives fine. It’s really weird…
      02-29-2024, 09:47 AM   #7
Mateusn55
Mateusn55's Avatar
Poland
Drives: Bmw e92 n55
[QUOTE=Hoody007;30936507]
I'll tell you honestly, it sounds identical. I also hear it on the passenger side, it is most audible when driving slowly in 1st and 2nd gear. I'm also completely at a loss as to what it could be, as the car accelerates normally, it doesn't display any errors either, but it's terribly annoying, it's impossible to feel the pleasure of driving through this gear. I will be returning the car to a good mechanic sometime in April so I will let you know what it could be. Because we have the same problem.
Hoody0071310.00
      02-29-2024, 11:50 AM   #8
Hoody007
Hoody007's Avatar
Thought I was the only one!
I think I’ll go ahead and replace the boost solenoid. It’s in the same general area.
Also, this happens in neutral, or in park. Low engine speed, around when the turbo watergate opens. Points more towards the solenoid, come to think of it…
Do you have the PPK installed? My car came from the factory with it.
      03-01-2024, 06:41 PM   #9
Mateusn55
Mateusn55's Avatar
Poland
Drives: Bmw e92 n55
When you start to fix something and there is some progress then you can let us know if it has been fixed
My car has not been tuned
Hoody0071310.00
