      01-23-2020, 11:44 PM   #1
1er_vert
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
BMW code: 00A6D1
According to Carly - this code points to passenger-side junction box Additional Water Pump. If I understand correctly, is this the HVAC heater core pump that keeps bringing errors? I have no idea what the part actually looks like.... help!
TIA
2007 BMW Z4 3.0si - Hellrot
2010 BMW X6 M - Space Grey
      01-26-2020, 09:02 PM   #2
JMX6V8
JMX6V8's Avatar
Dominican Republic
Drives: 2010 BMW X6 50i
This is what you are looking for.
      01-27-2020, 11:22 PM   #3
1er_vert
How easy is this to change out? Are you sure this is for the E71 X6M?
      01-27-2020, 11:49 PM   #4
JMX6V8
JMX6V8's Avatar
Dominican Republic
It is not that difficult to replace the auxiliary water pump on the E71. It is located almost on the same spot on the M as in the diagram that I posted for the 5.0. The part number is different for M model. This is the part number for the M.
11517629917
Auxiliary water pump
And the link to RealOEM.com - https://www.realoem.com/bmw/enUS/sho...diagId=11_4390
      01-28-2020, 12:04 AM   #5
1er_vert
So, basically remove top engine covers and there it is?
      01-28-2020, 12:23 AM   #6
JMX6V8
JMX6V8's Avatar
Dominican Republic
Well, not that easy!! In mine, I had to remove the intercooler expansion tank. It is right below the small coolant tank. You may have to disconnect some to the intercooler hoses and move the tank to one side. I am not familiar with the location of the intercooler expansion tank on the M model but, the auxiliary water pump is right in front of the engine.
      01-28-2020, 12:36 AM   #7
1er_vert
Fair enough!
      01-28-2020, 12:37 AM   #8
JMX6V8
JMX6V8's Avatar
Dominican Republic
Here are the instructions on how to replace it on an M model. https://www.newtis.info/tisv2/a/en/e...lines/CM8oUyq3
      02-21-2020, 12:14 AM   #9
1er_vert
Pump Replaced.... but Error Persists
Is there a fuse or relay that controls this pump? Why does the Owner's Manual not have a listing of all the fusible links????
      02-21-2020, 12:55 AM   #10
JMX6V8
JMX6V8's Avatar
Dominican Republic
The link that I posted before have all the information you need to work on your vehicle. Here is the specific information you were looking for:
https://www.newtis.info/tisv2/a/en/e...oling/AGJ5HfdK
You will notice that it will depends on when your vehicle was manufacture. Here is a picture of what you are looking for in the link above.
Fuse location is F01
      02-21-2020, 01:04 PM   #11
1er_vert
My manufacture date is 11/2009. But, where is the damn fuse box located? I looked under the glovebox junction block and saw nothing but a few big harness connections. I simply wanna see if I blew any fuses....
      02-21-2020, 04:44 PM   #12
JMX6V8
JMX6V8's Avatar
Dominican Republic
There are under the cabin filter. Not to difficult to get to them. The harder part to take off is the junction box cover. It has 3 metal clips and plastic male portion holding it.
      02-22-2020, 12:28 AM   #13
1er_vert
I saw a fuse panel under the glovebox too. It's held down by a single green Philips screw and fold down.
      02-22-2020, 03:24 AM   #14
JMX6V8
JMX6V8's Avatar
Dominican Republic
I was searching around to see what else could it be and found out that the X6M has two auxiliary pumps. https://www.realoem.com/bmw/enUS/sho...diagId=17_0511
This one connect to the passenger side junction box. You may have to do some testing and see which one the two is not working.
      02-23-2020, 05:00 PM   #15
1er_vert
I'm beginning to think this may be a Carly error, as I hear the "something" still running, after engine shutdown. Or, is that the radiator fan? Can somebody confirm?
      09-16-2020, 07:33 PM   #16
hyeprofile
Drives: 2012 BMW X5 M (E70)
Another way of checking if you turbo cooling aux water pump is working:
