F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Individual part numbers for the BMW M Performance Brake Kit components
proTUNING Freaks
      03-11-2024, 03:50 PM   #1
PininMargherita
Drives: F32 + F22
Question Individual part numbers for the BMW M Performance Brake Kit components
Does anyone have the individual part numbers for the BMW M Performance Brake Kit components, or do you have suggestions on where I can find the part numbers?
I am trying to piece this upgrade together without buying the kit from BMW.
      03-11-2024, 07:57 PM   #2
Orion4
Drives: 2013 335i Sport Line Sedan
go to Realoem.com and enter the last 7 of your VIN.
      03-11-2024, 08:37 PM   #3
alohasurftoad
Drives: 440i gran coupe w/mppsk
i've been playing with the numbers myself and unless you have some crazy good deals, if you ala carte all the pieces in the M-Performance kit it will cost way more than buying a kit.
low ball park for just the calipers
2x rear calipers, $1500 ish
2x front calipers $2000 ish
      03-11-2024, 11:18 PM   #4
PininMargherita
Drives: F32 + F22
Hi - I already have the calipers. I’m going to paint them an oem color. I also have stainless steel brake lines. I need dust shields and whatever else is included in the kit
      03-11-2024, 11:19 PM   #5
PininMargherita
Drives: F32 + F22
Realoem is great and shows me all the possible variations but I’m hoping someone will have the specifics for this kit
      03-12-2024, 04:54 AM   #6
danb1979
Idiotic lifter of heavy stones...
danb1979's Avatar
1969
Drives: 2015 F31 325D M Sport touring
You need the parts that say S2NHA=YES
As an example:
Front discs:
https://www.realoem.com/bmw/enUS/sho...diagId=34_1949
Part no.2 - 34106797603 (grooved/slotted discs)
And pads:
https://www.realoem.com/bmw/enUS/sho...diagId=34_2012
Part no.8 - 34116865460
Brake dust shields are the same
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298
      03-12-2024, 02:13 PM   #7
rlesko
Drives: F30 335i
2012 335i  [0.00]
Most major online retailers give you a kit contents breakdown. For example this is from FCP euro
Front:
- Four piston calipers with pads, wear sensors, and hardware
- Dimpled, slotted and vented rotors (370x30mm)
- Rotor shield protection plates
Rear:
- Two piston calipers with pads, wear sensors, and hardware
This kit includes the following parts:
x1 01292230088 - Customer Information M PERFORMANCE
x4 07119904511 - Hex Bolt with washer M6X12-U1
x2 34106797603 - Brake disc, ventilated, w/holes, front 370X30
x4 34106864424 - Torx screw with washer M12X1,5X43 ZNS3
x1 34106875655 - Brake caliper housing, orange, left "M PERFORMANCE"
x1 34106875656 - Brake caliper housing, orange, right "M PERFORMANCE"
x8 34116868785 - Hex Bolt M6X12-10.9-MK-
x1 34116872081 - Protection plate left
x1 34116872082 - Protection plate right
x1 34116878882 - Repair kit, brake pads asbestos-free
x4 34206850536 - Hex screw with collar M12X1,5X32 ZNS3
x1 34206855485 - Brake caliper housing, orange, left "M PERFORMANCE"
x1 34206855486 - Brake caliper housing, orange, right "M PERFORMANCE"
x4 34211164044 - Hex Bolt M8
x1 34216792243 - Protection plate left
x1 34216792244 - Protection plate right
x1 34216887576 - Repair kit, brake pads asbestos-free
x1 34356792289 - Brake pad wear sensor, front left
x1 34356792292 - Brake-pad sensor, rear
x1 01292230090 - Installation instructions
x1 01292231936 - TUEV/manufacturer certificate
x1 01292231938 - TUEV/manufacturer certificate
https://www.fcpeuro.com/products/bmw...30-34112221445
What is your current car?
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo
      03-12-2024, 03:16 PM   #8
PininMargherita
Drives: F32 + F22
Incredible! I don't know how I missed that - That's just what I'm looking for.
I have a f32 428i 2017 with 6MT
rlesko238.50
      03-12-2024, 03:17 PM   #9
PininMargherita
Drives: F32 + F22
As an example:
Front discs:
And pads:
Oh, I'm super confused. I thought I needed 4 new Brake dust shields.
      03-12-2024, 04:06 PM   #10
danb1979
danb1979's Avatar
1969
Go onto www.realoem.com
Put the last 7 digits of your VIN into the box at the top of the page and it'll bring up your exact car
Look at the brakes diagram and check to see if there's only one part number for the brake disc shield.
IIRC they're all the same inc the M3 & M4
      03-12-2024, 05:21 PM   #11
rlesko
Drives: F30 335i
2012 335i  [0.00]
You might. Check realOEM with your VIN and compare to the kit. I forget which models, but some do need a different shield which would fit the larger calipers.
Also, the genuine rotors which are grooved and slotted, but not cross drilled, are known to make some sort of ticking sound which can be bothersome.
      03-12-2024, 08:10 PM   #12
PininMargherita
Drives: F32 + F22
Honestly I was going to go with the 2 part plain Zimmerman rotors I used my GF’s m240i
      03-12-2024, 09:33 PM   #13
E90lova
Drives: F30 335xdrive
Man you guys make this look real hard. I could sell you my M3/M4 front and rear with Rotors for way less than all that. I also have Seemlegit adapters. Just so you know use Ebay for lower cost low mileage used parts like the dust shields.
      03-12-2024, 10:00 PM   #14
PininMargherita
Drives: F32 + F22
Man, I'm just trying not to screw this up. I've only done routine oil changes and brake pads, this project is a level-up.
I've gotten conflicting info on whether I need new dust shields, but visually, I think the front 100% needs new dust shields. Someone mentioned I can just bend the existing ones back but I'd rather not and do this the right way.
Vin last 7: F713031
This is what I have on the car now for the rear:
Do you know which model BMWs came with the 370mm front and 345mm rear rotors so I can better ebay? Thanks for the suggestion
      03-12-2024, 10:01 PM   #15
PininMargherita
Drives: F32 + F22
Also, what is the "Seemlegit adapters" ?
      03-13-2024, 07:51 AM   #16
rlesko
Drives: F30 335i
2012 335i  [0.00]
Vin last 7: F713031
I believe it was the track handling package, but some cars did come with larger blue rotors from factory similar to the BBK that BMW sells which only comes in yellow, red, and I think gold? Have a read through this thread for determining your brake shield size - https://f30.bimmerpost.com/forums/sh....php?t=2004068
Its a carrier bracket which would adapt F8x calipers to F3x wheel hub, allowing you to put F8x rotors and calipers on.
      03-13-2024, 04:43 PM   #17
PininMargherita
Drives: F32 + F22
I would only need Seemlegit adapters if I was running 370mm in the back. I'm aiming for 370mm front and 340mm rear
      03-13-2024, 05:07 PM   #18
rlesko
Drives: F30 335i
2012 335i  [0.00]
You are correct in identifying that you don’t need those adapters for your plans.
      03-14-2024, 05:51 AM   #19
danb1979
danb1979's Avatar
1969
Vin last 7: F713031
It's all to do with how they were spec'd from factory and whether the buyer chose for the brake upgrade
They can be retrofitted to all F3X cars IIRC; you just need to ensure you run 18" wheels at a minimum to clear the calipers
      03-15-2024, 12:45 AM   #20
BG03
Drives: 2018 Glacier Silver F31
2018 BMW F31  [0.00]
I recently upgraded my brakes with the performance kit, but didn’t use the pads. If you’re interested I’ll letting them go along with the read dust shields. My car didn’t need them.
      03-15-2024, 09:50 AM   #21
PininMargherita
Drives: F32 + F22
I’ll send you a PM and discuss price! Looks like you’re local to me too
      03-23-2024, 03:44 AM   #22
SD Convert
Drives: 2017 430i convertible
I made a similar upgrade about 2 years ago.
Parts list:
https://f30.bimmerpost.com/forums/sh...3&postcount=15
Pictures:
https://f30.bimmerpost.com/forums/sh...4&postcount=23
Thread:
https://f30.bimmerpost.com/forums/sh...php?p=26543141
2017 430i w/ Strut Brace / M-Perf brakes / M-Sport anti-sway / 255/40/18 square / iDrive-6
f30post
