      01-12-2009, 01:06 PM   #1
archwerks
Drives: x6 3.5i VR
Castrol SLX Motor Oil
BMW Magazine has Castrol SLX Professional Powerflow advertised.
Does anyone know where to buy some?
And how believable is BMW when u don't need to change motor oil for the first year or 2 / depending on your mileage travelled?
      01-12-2009, 03:09 PM   #2
xDrive50i
xDrive50i's Avatar
Drives: '09 750i individual
Do a search in this forum. This has already been discussed sometime in the May to July timeframe of last year I believe.
2009 750i individual | Citrin Black Metallic | Platinum Merino Extended Leather | BMW Individual Composition Package (includes Sport Package) | Dynamic Handling Package | Multimedia Package | Technology Package | Executive Package
http://www.7post.com/forums/showthread.php?t=234432
      01-12-2009, 03:30 PM   #3
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
Larger oil capacity, better oil and filters have all improved where the 2500 mile oil changes are no longer required.
Many old schoolers will argue this point.
Since no one has had an engine failure due to 15k oil changes, I would say there is not an issue.
2011 535i
2008 VW GTI
      01-12-2009, 04:48 PM   #4
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
Since no one has had an engine failure due to 15k oil changes, I would say they are not an issue.
+1
I used to be skeptical but after running a couple of X5's hard including time in the desert and the snow I have to agree.
      01-12-2009, 05:06 PM   #5
Deda
Deda's Avatar
Croatia
564
Drives: BMW M5 comp
Originally Posted by dmlgc View Post
+1
+1+bmw x3!
      01-12-2009, 07:42 PM   #6
archwerks
Drives: x6 3.5i VR
Thx guys.
      01-13-2009, 08:54 AM   #7
Suzie's Dad
Suzie's Dad's Avatar
Drives: ML550/AMG
I have been arguing for about six years on the Roadfly X5 forum that the days of 2,500 mile oil changes are long gone as long as you use a true ester-based synthetic oil. It isn't "old schoolers" who tended to disagree, but mostly the young guys who have grown up indoctrinated in the idea of frequent oil changes. It isn't generally the oil itself that degrades these days, it is the additives that get used up. Many truckers go for up to 100,000 miles on the same oil, just replenishing the additives and changing the filter periodically. Not that I advocate that for the X6, but it does give an idea of how long modern oils continue to lubricate. (Synthetics don't break down under heat and 'shear'; mineral-based oils do.)
BMW recommends changing oil annually even if you don't put on enough miles to trigger the light. I think this is just to make sure that water is removed from the crankcase, because low-mileage vehicles are generally used for short trips, which means the water in the oil never gets a chance to burn off.
      01-13-2009, 12:06 PM   #8
xDrive50i
xDrive50i's Avatar
Thanks SD for the short but still informative write up
