08-01-2014, 03:49 PM | #1 |
New Lifetime Replacement Policy
813
Rep 11,738
:: ECS Tuning :: E53 X5 Coil Spring Conversion Kit|Air Be Gone
If your factory air suspension has given you problems in the past, or if you simply refuse to replace the outrageously expensive suspension parts knowing they'll probably only again fail, a wise alternative is a Coil Spring Conversion Kit from ECS. High-quality progressive-rate coil springs eliminate the troublesome air bags while retaining the smooth, luxurious handling of the original setup. Simply pair this kit with your choice of shocks and struts for a complete air ride delete. Click HERE for more information! |
