      07-25-2015, 06:35 PM   #1
Doc GTO
Wicked Fast +1
Doc GTO's Avatar
Drives: 13 X5 50i MSport/02 M3 Track
My X5 50 MSport W/ H&R and ECS Spacers
I just had my race shop install my H&R 1.2 inch drop kit with ECS 12.5mm front and 20mm rear spacers. I also did a custom alignment so I can get more then 7K on the tires!
The shop got the H&R kit in with zero problems and measured the links with digital calipers to 65mm and it had the proper nose down rake and was dead level side to side on the 1st try. The ride is firmer with lass body roll but it is not too harsh and haven't experienced any significant bounce. I'm very happy with the mods and new alignment.
The stock alignment was absolute crap... There was enough toe-in to kill and rear negative camber to kill tires quick.
Stock alignment was as follows
Front:
-.07 camber
.20 toe in left and .17 toe in right
Rear:
-2.5 camber
.20 toe in left and .23 toe in right
New alignment
Front:
-.07 camber
0.0 toe both sides
Rear:
-1.0 camber
.02 toe in each side.
Truck feels so much more nimble and the turn-in is more crisp and feels like to wants to actual turn!!! LOL Before it felt like a slug.
Here are a few photos I took today before the afternoon rain.
I do want to go in and paint the hubs for a cleaner look:
Doc
2013 X5 50i M Sport/BMS Stage 1/Magnaflow/P3Cars gauge/H&R 1.2/Style 215s
2002 M3 Race car bimmerworld/Turner/Markert modified
      07-26-2015, 08:30 PM   #2
EPT535i
EPT535i's Avatar
Drives: F10 535I
Looks good, what are the specs u used for the custom alignment.
F10 535I ALPINE WHITE MSPORT
      07-27-2015, 10:56 AM   #3
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
painted hubs and calipers make a big difference
      07-27-2015, 08:28 PM   #4
Doc GTO
Wicked Fast +1
Doc GTO's Avatar
That's on the to-do list.
Doc
      07-27-2015, 08:29 PM   #5
Doc GTO
Wicked Fast +1
Doc GTO's Avatar
It's in the original post after the stock specs.
Doc
      07-28-2015, 01:59 PM   #6
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
How are you liking the zero and .02 toe in? Probably still too early to tell tire wear wise, but I am curious. I'm currently at .02 toe in on the front and .06 toe in on the rear and have been thinking of going less. My concern has been the awd system pulling the wheels back so a zero toe like you have would then turn into toe out on acceleration. You experiencing this at all?
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      07-28-2015, 07:12 PM   #7
perrymaxima
Drives: E70 X5 M Sport
Good question I need the answer as well!
      08-02-2015, 01:20 PM   #8
Doc GTO
Wicked Fast +1
Doc GTO's Avatar
No negatives noticed at all. It actually feels like she wants to hit the corners and turn! With all that toe-in before, she liked to go straight... I just got back from a trip and the truck was great on the highway. Nice manners as you can expect from a vehicle with as wide a tire as we have. It also appears that with less toe-in, we have less scrub. I did average about 20.5-21 mpg with the new alignment. When I bought her home from the dealership on the stock alignment, I got 19.5-20.2. Same route and same 79 mph cruise.
As far as toe, for the toe to change, you need a big force to move the suspension pickup points. Under acceleration (from the powered tire rotation) you would get more toe-in and under braking, more toe-out. With zero toe in the front, you could experience some monitor toe-out under hard braking which could cause some wandering but usually you only get this with substantial toe-out like on a track only car. Even my track car barely has any of that and I run more toe-out and a crap load of negative camber.
So, with all the toe-in we have stock, hard acceleration would just cause more. The stock alignment is designed for the car to have straight line manners and be more stable on the highway to compensate for the massive tires we have so it doesn't tramline all over.
Also, the Germans think we cannot drive so they set up the vehicles to understeer mores then neutral or oversteer. My setup may cause a little tramline (nothing that is harsh at all) but she is nice and neutral and feels so much more athletic in the curves.
I'm not a pro by any means but after 21 years of road course experience and suspension setup and after setting up Alfas/911s/E46 M3s for the track, I have my fair share of alignment experience. I always go for neutral to slight oversteer and better turn-in over a dead wheel, tire destroying, understeering pigs for the street!
Doc
      08-02-2015, 06:55 PM   #9
DKNJX5d
Drives: 2011 X5d
Looks amazing I did a similar setup with 17mm spacers all the way Around and my left side for some reason sits lower which puts me out of spec. On camber and cross camber.
      08-02-2015, 07:10 PM   #10
P1
P1's Avatar
11554
Drives: 2004 3/4 ton Duramax
Looking very proper mate, always liked those wheels...
      08-03-2015, 07:00 AM   #11
Doc GTO
Wicked Fast +1
Doc GTO's Avatar
Did you have. Alignment done after the lowering springs and the spacers? The spacers will change the specs slightly since the wheelbase is wider. I would check the links to make sure they measure the same length. Some shops will eyeball it but they need to be measured with a caliper to the mm.
Thanks!
Doc
      08-06-2015, 07:19 PM   #12
Gatoferoz25
BeastM3r
Gatoferoz25's Avatar
Drives: M3 COMP
looks good brother
MORR WHEELS - VORSTEINER HOOD - FRONT LIP-CF REAR DIFFUSER - LED HEADLIGHTS - BREMBO BRAKES - Kw SUSPENSION - EISENMMAN - JB4 - SPORT STEERING WHEEL..!
