F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > mice chewed OIL LEVELLING SENSOR cable
Studio RSR
      01-28-2019, 09:02 PM   #1
anh3
Drives: 2017 340 xdrive
Wrng.harness,motor,sensorsystem,module
Part Number: 12518631656
Part Number: 12618638755
Part Number: 12518631656 is a whole harness that connects to alot of other modules, the damage is only on the end connecting to Part Number: 12618638755; the darn thing chewed through the wire. I'm thinking I only need to splice and reconnect the two wires, any thoughts? I did take a look while tech had car on lift and it wasn't a clean 'cut', does look like something chewed on it, the wire cover had a U shape missing on it...
came back from two weeks of vac. and notice car message said oil life is 600 miles left. Went in for routine 1 year oil change, tech found it and the oil life indicator won't reset, message still said I have 600 miles left on my oil-after change. The car is still driveable.
      01-29-2019, 08:56 PM   #2
munu
Drives: 2014 F30 Msports
It happened to me twice within 4 months. Paid almost $400 every time. I still doubt that it was mouse but the cable was split. I now got the aluminum sheet wrapped over the cable.
eluded3070.00
      01-29-2019, 08:57 PM   #3
munu
I had exact same symptoms as you. Miles left dropped from 5000 to 600 which I think is default if sensor is not working. Dealer told me that they got couple of such cases every month.
      01-30-2019, 10:03 AM   #4
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
This is interesting. Is there some sort of cable shielding option, for example flexible metal mesh which some rubber hoses have (not necessarily BMW rubber hoses)?
      01-30-2019, 10:12 AM   #5
grancouper428
Drives: 2015 BMW 428i Gran Coupe
Had this happen once the BMW tech caught it during my routine maintenance check. I believe I paid around $250 to fix it.
      01-30-2019, 11:49 AM   #6
bimmer456
Drives: 340i
Sux how this costs less than insurance deductible. If it happens multiple times that is worse. And mice can chew through metal unless it is thick enough.
      01-30-2019, 05:52 PM   #7
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Mice can also total a car if they chew through something that's part of the wiring harness - that is a massive job to replace.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      01-30-2019, 06:22 PM   #8
EDWYER
Yoda of mods
EDWYER's Avatar
1678
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
Get some mouse traps as well.
Current: 2020 Explorer ST (Agate Black Metallic) AWD, F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired)
Follow me on Twitter: https://twitter.com/EdwyerCLT
YT: https://www.youtube.com/@DWYERGARAGE/videos
      01-30-2019, 06:29 PM   #9
BEM-S4
BEM-S4's Avatar
Apparently mice HATE the smell of Bounce sheets so if you leave an open box in the trunk of your car they will stay away. I've got a box in both of my cars that are stored for the winter.
2022 Macan S
      01-30-2019, 07:06 PM   #10
5mall5nail5
Not stock
5mall5nail5's Avatar
Drives: E34 525i Turbo
tried dryer sheets. doesn't work. peppermint oil has worked so far. repaired the engine harness in my Dodge ram about 4 times now... one time was a HUGE pita. they chewed every plug wire, distributor timing sensor, etc. etc.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM
1992 525i
1987 325e
      01-30-2019, 07:31 PM   #11
anh3
I was dumbfounded when the SA quoted me a little over $2k, mostly for labor I guess. I OEM part/harness online is around $400, but man $1600 for labor. I'll try the splice and reconnect method and see how it goes.
The wire was shielded in the ribbed black plastic you commonly see, no match for the mice though. It chewed through the copper wire, completely separated.
      01-31-2019, 10:05 PM   #12
munu
I have never seen a mice around my house. Even I put a trap for couple of weeks but didn't see anything. Still I was hit twice within 3 months due to this harness chewing issue. I even have warranty but dealer won't use it.
I didn't see the cut the first time but second time when I saw it, it was clean cut through the tape. Hard to believe it was mice but I have no other answer. Don't understand why mice would attack the same part of the cable.
2014 BMW 335i - M-Sports, 19inch 403 Wheels, M-Sports Brakes, Tech pkg, Prem pkg, HK, SunShades, Auto, Driver Assist...
      02-01-2019, 01:43 PM   #13
anh3
I had the same thought, mice?! But then I traced back... had the oil changed this last summer 2018, puts less than 6k miles on it, went on vac. for two weeks, first morning back notice the oil life message "less than 600 miles." SA also said not under warranty since this is a damage and not manufacturer defect, reasonable enough unless there was a 'mice' included in my 340i that I didn't know about?
the first mice probably left some scent in your case (or just the same mice?!), and the plastic shielding's probably got some dino-juice-scent=food in it (after all plastics are made with oil). That's my half educated guess! The plastic shield actually is missing a chunk, so something actually ate it. Not the first time in general, I've seen electrical wires and plastic things that mice (or something) chewed on.
      02-01-2019, 06:13 PM   #14
AndDown
Just Copacetic!
Drives: 2019 F22 230i MSport
Here’s another rat thread from the F22 forum:
https://www.2addicts.com/forums/show....php?t=1446834
I'm putting out some rat/mice bait right now!
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSptPkg AlpWhite
      03-18-2024, 08:23 PM   #15
f30darknight
Drives: BMW 328i n26
I know I'm late to the party. Google search tells me this is the most relevant post about this topic. And I see no one gave this man help on how to fix this issue. I too have this strange cut in my wiring harness near the base of my oil level sensor. Besides telling me any more about mice, has anyone spliced this? If so, can you direct me to the correct wires? Thanks
      03-18-2024, 09:46 PM   #16
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Splicing isn't difficult, under the wrapping they're all color coded.
      03-28-2024, 01:10 PM   #17
f30darknight
Helpful. I’m asking people who have encountered this experience and what they’ve done. If you’re not here to help just don’t comment. No kidding splicing isn’t difficult, I’m prepared to.
      03-28-2024, 01:15 PM   #18
Billfitz
Billfitz's Avatar
I have encountered this experience and spliced the wires. I don't know what you're here for but whatever it is it won't matter to me, blocked you are.
      04-21-2024, 12:04 PM   #19
Cesarherc
Cesarherc's Avatar
Drives: 328i BMW
2015 328i  [0.00]
2015 328i  [0.00]
I’ve had this same issue and looked everywhere for a pigtail replacement, unfortunately I haven’t had any luck, only place I found this and just put an order for it is on the Ali express app, a china product but seems like it will fit, once I get it I’ll see if it fits and report back.
      04-28-2024, 07:14 PM   #20
Cesarherc
Cesarherc's Avatar
Drives: 328i BMW
2015 328i  [0.00]
2015 328i  [0.00]
Hey all just wanted to confirm this is the correct piece but for my car it was the second one, the one that says color B, if you look carefully the notches are reversed on both so chose the best one for you.
f30post
