      07-13-2022, 02:25 PM   #1
Alibmwx6
Drives: Bmw x6 e71 2012
2012 bmw x6 e71  [0.00]
Hi bimmers how are you all?
Here is my little problem
I did code my bmw x6 e71, I didn't backup (I hope you all can help)
The trunk doesn't want to open with key fob, I can close with key fob, I can open with inside button and close but not with remote(key fob)
I don't know what I touch but seem like happens nothing when I'm push the open trunk from key.
Coded with bimmercode ( i coded a few things,like close the trunk soft, or lights , coded the mirror when you lock the dors from outside, Coded bluetooth audio, and others...
So what can I do to rivive the key fob to open trunk?
Where should I look in bimmercode to fix ?
      07-14-2022, 05:06 PM   #2
Alibmwx6
I found out my self
In bimmercode go to
Car acces system then you will see
Rear windows open with remote key
Make it non active, if active then the key fob the trunk not going to open.
That's it.
      10-29-2022, 10:17 AM   #3
JRockman
Drives: BMW X6M
2013 BMW X6M  [0.00]
Does bimmercode actually work? Who else is using this? Any negative outcomes yet? Curious more than anything. Thx
      12-05-2022, 11:50 PM   #4
Alibmwx6
Well. I think better using bimmercode if your not super professional coding,
Using bimmercode it's easy, before any coding do a backup.
Or if you interested to code more, you need a laptop, software bmw, (e serie, f serie etc..)
And good luck to code.
But as I said if you need the only 2 things to code
Use bimmercode or carly, bimmercode ots more like for expert, carly doesn't have expert mode.
