      01-26-2021, 02:46 PM   #1
zoom750
Drives: 2013 X5M
Looking for information on X5M auxiliary water pump
I have a 2013 X5M that has a slight coolant leak on the passenger side. It looks like the auxiliary water pump is leaking at the connection at the top. BTW, this is not the pump that cools the turbos after the engine is shut down.
Wondering if anyone has any experience working on this pump. I will need to replace the hose, which I assume connects to the small coolant tank on the passenger side (hard to tell where the top of the hose connects to on RealOEM). It's buried in the engine, and think that the best way to access is through the passenger wheel well.
Wanted to check with the board before digging into the repair.
Thanks.
      01-26-2021, 09:24 PM   #2
TwinSnailz
TwinSnailz's Avatar
77
Drives: 2011 X5//M
Most of the time it is the coolant temp sensor that located on the radiator hose that is right over that aux pump. Its the o-ring that goes bad. Check that first, might save you time and money.
      01-27-2021, 06:06 PM   #3
zoom750
Drives: 2013 X5M
Thanks for the suggestion. Are you referring to part#21?
      01-27-2021, 09:34 PM   #4
TwinSnailz
TwinSnailz's Avatar
77
Drives: 2011 X5//M
Yes correct
      07-12-2021, 10:03 AM   #5
mightyb28
Drives: BMW Z4
Does anyone have a picture of the engine bay with the aux water pump location? I have the A6D1 auxiliary-water pump fault code and it's telling me I need to replace the pump, but I am not sure of it's location and if it's the sensor o-ring, or I should just locate the pump and replace it.
      07-12-2021, 01:29 PM   #6
zoom750
Drives: 2013 X5M
On the S63 engine, there are two auxiliary water pumps. You can check realoem.com for your specific VIN, although they should be identical.
https://www.realoem.com/bmw/enUS/sho...diagId=17_0511
This youtube video shows how to access the passenger side pump.
