Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Have an idea for a a custom exhaust I want to try out need input
      01-13-2014, 10:31 PM   #1
e92_bryan
Drives: ‘11 e92 328
Disclaimer: if i say something stupid its only because I have only seen my car on a lift twice and its hard to find a full factory exhaust picture on google.
Please correct me if I'm wrong but isn't this how the 328i e90s exhaust is?
1st headers w/primary cats then 2 resonators that form into a y-pipe then some more piping then secondary cats, more piping then muffler?
If I'm write, which I'm not exactly 100% sure
I'm thinking about doing a custom set up, but I have 3 ideas
Option #1 resonator delete with a custom y-pipe to replace it
Option #2 resonator delete with an x-pipe at the point where they are supposed to meet and then run dual pipes until the secondary cat and turn it into y-pipe there
Option #3 resonator delete with and run dual pipes and towards the end farther away from the resonators do an x-pipe quickly followed by a y pipe into the secondary cats
The difference between 2 and 3 is the location of the x-pipe, 2 is right after the resonators and 3 is before the secondary cats w/ a y-pipe
Also are there any possible gains from one of these set ups? and which is most likely to be the loudest, including a muffler delete I already have?
*UPDATE*
Ok thanks guys I had the order of the 2nd cats and resonator mixed up.
I know you can't pass smog without primaries but what about secondaries.
So here are my new ideas
Option #4 x pipe after the second cats and replace resonator with a y pipe
Option #5 y pipe right after 2nd cats then delete resonator and run single all the way to the tips
Option #6 juts a resonator delete replaced with a y pipe
      01-14-2014, 01:59 AM   #2
gewse2k
Netherlands
19
Drives: 2014 F30 320i
headers with primary cats =into= secondary cats =into= resonator (which is also y-pipe 2 >1) -into- muffler.
Just the part between the resonator and muffler is single piped.
At the moment I have an x-pipe instead of the resonator and a muffler. So 2 pipes all the way from front to back. Sound outside the car is great... but because of the resonator delete there's an enormous drone inside the cabin between 1500-2500rpm. And it's a wagon, so i think thats part of the problem.
But because I have a euro car I don't have secondary cats.
      01-14-2014, 08:25 AM   #3
Dylanize
Captain Dutch Rudder
Dylanize's Avatar
204
Drives: AMG
Some people have noticed loss of torque with res deletes. Back pressure is a big part of that, more so with NA engines. How ever I have seen good gains from removing the 2ndary cats while leaving the res. plus a muffler delete.
No more E92 or E82
      01-14-2014, 09:11 AM   #4
Rival
Drives: 95 z28
i plan to delete the res + 2nd cats
leave primary cats and stock muffler in place.
2010 335i M sport
2008 328i
2006 325i
1995 Z28 6spd - 377rwhp rip
      01-14-2014, 10:27 AM   #5
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Just no.
\\\\\=>-------------[--]----[--]= Headers to Y pipe and a single pipe all the way back into a resonator and then a muffler
OR
\\\\\=x========[--]===[--]= Headers to X pipe and dual piping all the way back into a resonator and then a muffler.
      01-14-2014, 07:50 PM   #6
e92_bryan
Drives: ‘11 e92 328
Bump
      01-14-2014, 09:02 PM   #7
Taskmaster
Japan
2465
I just gave you the best answer, what else are you looking for?
      01-14-2014, 09:40 PM   #8
Love The Drive
Love The Drive's Avatar
Drives: E90 MT N51
Don't Remember what thread this was from, but I had a screenshot of it so here you are.
From headers + main cats to..
..to muffler and tips.
2011 E90 328i | CDV Delete | BMW PE | Bilstein B12 Pro-Kit | 17x9 ET30 APEX ARC-8's | 255/40
      02-11-2014, 08:52 PM   #9
F82M4
Drives: E92 335i '10
I say do a resonator delete along with a muffler delete and test that out first. If you have drone issues or don't like the sound, go from there. But, you will lose some backpressure due to no muffler or resonator so what I would do is delete the muffler and resonator, and put a nice free flow muffler or a resonated X-pipe in place of the resonator to dual tips.
      02-11-2014, 10:45 PM   #10
Taskmaster
Japan
2465
      02-12-2014, 12:02 AM   #11
SDemetris
FSAE Dude
Drives: E90 328xi
Originally Posted by TheAxiom View Post
haha agreed. This is a totally solved problem. Listen my axiom on this. I personally would do his first option of one tube because racecar, but you're the captain of your own ship. Go completely straight piped like the dude with the e92 that got the MMW headers first a while ago if you really want.
2007 TiAg 328xi: AA Tune, AFE intake, Full exhaust, 335xi Brakes, H&R RSB, UUC FSB, H&R Sports, Billy Sports...BBS SR 17x8
1985 Gazelle Beige 325e: Poly everything, e24 3.25 LSD, 225 lb weight reduction, Corbeau FX1, Shifter machined by me, roll bar, harness, all the other goodies. My "Racecar"...15x7 BBS RA
      02-14-2014, 10:15 PM   #12
e92_bryan
Drives: ‘11 e92 328
Update, i just did a basic resonator delete and I already had my muffler deleted as well, the resonator made a world of difference
      02-19-2014, 12:10 AM   #13
F82M4
How did they attach it? Straight pipe or y pipe? Do you have any clips? Pictures?
      02-19-2014, 11:01 AM   #14
Dylanize
Dylanize's Avatar
204
Drives: AMG
Did you notice any lack of torque after removing the res???
No more E92 or E82
      02-19-2014, 03:03 PM   #15
mike-y
just another bmw douche bag
Drives: 1.9L of fury
*UPDATE*
As long as your smog tech doesn't look under the car, you should be able to pass.
IF the guy looks under the car, and sees you don't have the secondary cats, it's an instant fail. CA requires a visual check of components as part of the smog test. Chances are usually pretty good that they won't look though.
Tags
328i, custom exhaust, resonator delete, x pipe, y pipe
