12-31-2013, 09:35 AM | #2 |
Rep 7,341
Cobb AP, Exhaust, I liked the BMW Perf side skirts on mine but it was gray and they may not be as apparent on a darker color.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold |
12-31-2013, 12:38 PM | #4 |
Rep 203
I like the side skirts also and will be doing them in the spring. Somehow they Lessen the pot belly affect the sides of the 1's have, in my eye.
They'll be my only exterior mods besides the tint and perf kidney grills. |
12-31-2013, 12:41 PM | #5 |
Rep 4,154
Drives: 1/18 Monte Carlo Blue E92 M3
JB4, Downpipes, Berk Exhaust, CF 3 Fin Diffuser, SleK Front Lip, Spacers for stock wheels, New Tires.
12-31-2013, 01:19 PM | #6 |
Rep 96
Drives: 2010 dadmobile
Tune
Exhaust Intercooler Intake Charge pipe/bov Oil catch Thermostat LSD Suspension Wheels/tires Body mods if you're into that..the Reiger M kit is beauty or some carbon if you like Post pics when you're done. Thanks! Do a search on here too, there are tonnes of build logs/posts to give you ideas of what you're looking for and willing to shell out. |
12-31-2013, 05:43 PM | #8 |
Proud AARP member in good standing
28
Rep 635
It's nice when other people spend your money
What's your budget? What do you want to have? HP? Handling? Exterior go fast body parts?
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver. |
01-01-2014, 06:22 AM | #10 |
Rep 409
Drives: 2008 Montego Blue 135i
Suspension.
There are no impossible deeds, only incapable men.
Eibach frontsway,BMS JB4,AFE Drop InBerk Street Axleback, H&R SPORT SPRINGS,Active Autowerke DP's ,Active Autowerke BOV,Active Autowerke FMIC , BMWPEDALS.COM, JB SPEED Black Grills,Alpina B3 TCU Flash |
01-01-2014, 07:55 AM | #11 |
Rep 837
Drives: 2009 BMW 135i Sport package
First off, Tint the windows.
01-01-2014, 09:09 AM | #13 |
28
Rep 635
01-01-2014, 12:11 PM | #14 |
Rep 961
Cobb is the easiest tune to use. You program via the ODB II port, no other equipment is required to be installed. When you want to take the car to the dealer, reconnect the Cobb, choose uninstall, and wait about 20 minutes for it to be flashed back to stock. Highly recommend.
01-01-2014, 12:21 PM | #15 |
Rep 454
* Window tint (sunroof too).
* Slotted/drilled rotors. Can't wait to see pics of whatever you decide.
2013 Jet Black 135is | 6MT | Coupe | #381/586
01-01-2014, 12:36 PM | #17 |
///M
Rep 28
i would definitely recommend you get a JB4 chip from burger tuning! for under $500 you'll add about 100whp to a completely stock car...well i know it's about 100whp to a stock 335 and jumps the boost up from 8-9psi stock to 13-16 depending on what map you have it on. Definitely look into the JB4 i guarantee you'll want to get it! it's also very easy to install
01-01-2014, 12:50 PM | #18 | |
Rep 961
01-01-2014, 01:53 PM | #19 |
Rep 178
I've done lots of reading and there's simply lots of mixed opinions. so based on my research and I've owned my 135i for almost two months and found the mods that I have a perfect starer combo .
I have BMS DCI and also have their Drop in filters and Cyba scoops and for some reason it seems to deliver smoother power on mid and top end of the RPM .( I run them both periodically ) FMIC is a must , I was loosing major power due to heat from the stock IC which is a POS IMO Specially running higher boost . The VRSF 7" is great and can definitely keep things cool at all conditions, optioned for the 7" in case I go big down the road (5" ones will do just fine ) Jb4 is a no brainer and You will simply love it once you get it figure out . Also running stock exhaust and have no plans on changing it . DP & Tires are next on my list so take it for what you will . GL Last edited by m4xm1l10n; 01-01-2014 at 01:59 PM.. |
01-13-2014, 04:21 PM | #22 |
Rep 3,732
Drives: BMW S1000XR
Depends on your budget. I spent $14K on mine and about $6K on my 335i. GL
BMWCCA member |
Tags |
135i, bmw, n54 |
