12-01-2013, 08:46 PM | #1 |
Rep 4
Oil level indicator
The oil on my 3.0si was due a changed, so I changed it with the Germany Castrol 0w-30 syntec (7 qts) and used a OEM filter. Everything was fine and dandy until I checked the idrive oil levels and it showed that my oil is at the minimum. The idrive never showed a error when I started up the car nor a low oil warning, or a sensor malfunction. Has anyone ever had this problem? Did I not add enough oil? Though through my research I had found out that I only needed 7 qts.
