      07-03-2014, 01:54 PM   #1
MRLIMPORT
Drives: bmw F30 WHITE, X5 2013 BLUE
Unhappy engine fan relay location
Hi Guys,
I need some help. I have purchased a x5 e70 2013. After a accident i had to change the engine fan. therefore the fun is working only on the second stage so it is very noise. After a research a found that the problem could be cause by the relay. However i am not being able to locate the fan relay to exchange. Can someone help me on this issue?
Thanks, Marcelo
      07-04-2014, 10:29 PM   #2
ingenieur
ingenieur's Avatar
24
Drives: 2011 335d MSport
I believe if the relay was the problem the fan would not operate at all. See the attachment - more likely the DME may be setting a fault for an engine temp. related input and controlling the fan to high spd.
      07-07-2014, 09:48 AM   #3
MRLIMPORT
Thanks for your reply. I will get it checked today.
Tags
e70, engine fan, relay, x5 35ix
