      01-15-2018, 04:18 PM   #1
Teq
Drives: E90
Led headlights + heated steering wheel retrofit worth the money
I recently did a led headlights retrofit with a heated steering wheel which are definitely worth the money.
Removing the headlights was a lot of work. The wiring is pretty straight forward after installing and coding they should light up. Ncsexpert is all you need.
The wiring for the heated steering wheel is also easy but takes time to install it correctly.
If someone has any questions regarding these retrofits do let me know.
