      11-13-2018, 04:16 PM   #1
r1sc
Drives: 2012 X5M
Brake Fluid DOT4 or 5.1?
2012 X5M, what's the preferred fluid and why isn't this in the manual?
Plan to use my Motive power bleeder, any special considerations or is it just like any other car?
      11-13-2018, 09:05 PM   #2
omgboost
Drives: 2012 X5 35i
I use pentosin dot 4 lv ony 35i. Change was very simple using the motive power bleeder. Although mine wouldn't hold pressure for an extended time
      11-15-2018, 03:32 PM   #3
racermp
racermp's Avatar
Drives: F30 330i
Do not use 5.1, it's ment for specific cars
Check the brake fluid cap on the car
      11-15-2018, 05:09 PM   #4
cbakking
Drives: E70-X5M
I just got brake flush done, they (dealer) used DOT4
      11-16-2018, 05:15 PM   #5
nlastovi
Drives: 2011 x5 50i
DOT 5.1 (not DOT 5) is an upgrade from DOT3/4 and is fully compatible. It is less viscus (in other words, thinner) and has a higher boiling point. All else equal it would be considered somewhat superior.
      11-16-2018, 05:23 PM   #6
Kraftwerk AG
Kraftwerk AG's Avatar
Drives: Mein F Fünfundachtzig Einhorn
Correct!
      11-16-2018, 06:09 PM   #7
racermp
racermp's Avatar
Drives: F30 330i
Sorry my bad, I was thinking 5. Hehe
      11-17-2018, 01:05 PM   #8
nlastovi
Drives: 2011 x5 50i
Originally Posted by DeeO View Post
Correct!
My understanding is that 5.1 was originally developed (and, IMHO, poorly named) in association with antilock braking systems. Having a somewhat less viscous fluid would make it a bit easier to move during rapid on/off sequencing associated with ABS. That it has a higher boiling point is great too when subjected to extremes.
There are some DOT 3 and 4 fluids as well with much higher boiling points intended primarily for competition applications. Motul Rbf 660 Dot-4 for example has a dry boiling of 617°F and wet boiling point of 400°F.
