Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos
      01-23-2016, 07:06 PM   #1
Apex Everything
Apex Everything's Avatar
Drives: M3
Best low profile jack options?
I am going to be buying a low profile jack in the new few weeks, they appear to be in the $150-200 range.
What are some good options?
I see JEGS has one, Tire Rack does too. Who do you use?
      01-23-2016, 07:13 PM   #2
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
harbor freight low profile 3 ton jacks, $80/ea
I bought 2
      01-23-2016, 07:18 PM   #3
Apex Everything
Drives: M3
I bought 2
Hey man, I appreciate the response.
Growing up, I was taught to know that harbor freight was the lowest on the totem pole in terms of quality, meaning more likely to break.
      01-23-2016, 07:19 PM   #4
Real Nice Guy
Real Nice Guy's Avatar
31
Drives: 2008 e90 M3
Yep, Harbor freight 3 Ton!
http://www.harborfreight.com/automot...ump-62326.html
Stay away from the aluminium jacks.
      01-23-2016, 07:21 PM   #5
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
I've been using HF jacks for 5 years now. It looks so beat up but still works like a I bought it on the first day. Of course, anytime you get under the car, jack stands without a doubt
But changing wheels like I do often, it's a great jack
      01-23-2016, 07:22 PM   #6
Apex Everything
Drives: M3
What is wrong with Aluminium ones?
      01-23-2016, 07:25 PM   #7
Real Nice Guy
31
Drives: 2008 e90 M3
They start to bend and twist after some use.
      01-23-2016, 07:31 PM   #8
overcoil
Drives: M235i 6spd
Arcan 3 ton from Costco? Profile height is low enough for 235 rocker panel rubber lift points along with a jack pad.
This jack is heavy.
I've had Sears aluminum racing jacks and I like the Arcan better.
These things are nice
http://www.brunnhoelzl.com/home.html
      01-24-2016, 01:14 PM   #9
PetersLab
Drives: None yet....
I just pick up the cheap low-profile jack from Pepboys. As mentioned before, you should always be using jack stands anyway so spending a few hundred on a jack seems silly to me
      01-24-2016, 01:17 PM   #10
ahero4eternity
Drives: bmw
I use this: http://smile.amazon.com/dp/B007G83T1...7WWF24W0&psc=1
One of the few jacks I can find that is low enough for me to use without having to drive onto 2x4 blocks.
Everyone I know uses the jack from Harbor Freight and they all love it.
I'd rather spend the extra money for peace of mind. It's not like I have to buy a new jack every year, so a the extra $150 over the HF jack is worth it to me.
      01-24-2016, 02:41 PM   #11
David70
Drives: 06 Z4M Coupe - 13 Cadillac ATS
I have had the HF aluminum jack for about 3 years. Works as well as the day I got it, no issues with it bending or anything else. Also have a perfectly smooth garage which may help.
Only thing I don't like is the extended height is pretty low, probably would have purchased one of their other jacks because of this issue. They list the extended heights on the website specs.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
      01-24-2016, 02:46 PM   #12
STOOF
Sunburned
STOOF's Avatar
Drives: '16 F83 M4 Convertible 6MT
2013 BMW 535i  [0.00]
+1 for the Harbor freight jack.
@ $80 if it breaks you can go buy a new one and still be ahead.
2016 M4 Convertible 6MT - SO/SO
2013 535i 6MT MSport - Retired
2011 Z4 SDrive35i 6MT- Retired
      01-24-2016, 03:02 PM   #13
JHY310
Drives: E92 335 / F80 M3 on order
I support the HF - but I also have a craftsman that's been running like a champ - needed fluid once but that's it. I think it was around 150 when I purchased.
      02-03-2016, 08:41 AM   #14
dagolfpro
dagolfpro's Avatar
Taiwan
248
Drives: 2011 E90 M3
The $100 Costco jack works great for me at home. For the track, I use the HF aluminum with zero issues.
2011.75 E90 AW | DCT | ZCP | ZCV | ZCW | ZP2 | Prem Sound | Moonroof | BMW Apps |
Mods List: Evolve Exhaust | M Perf Steering Wheel | Tint | Lux | Hardwired V1 | KW V3 | Volshlag CP | Brembo BBK | BBS FI | Yokohama AD08 R| Schroth 4 Point Harness | Challenge GT Diffuser | OEM GTS Wing| GTS Lip| I lied earlier, I wasn't done with mod, but I swear, I'm done now, no more mods...
      02-03-2016, 11:17 AM   #15
335e92
335e92's Avatar
131
Drives: 335i e92
I have used aluminum HF jack for over 5 years. No problems at all. Best jack for your money.
      02-03-2016, 01:02 PM   #16
turbo_joe
turbo_joe's Avatar
1616
Drives: 2012 M3 Coupe
HF aluminum 1.5 ton for me, its small and light weight and works as good as it did new (2 years old)
90% of my tools are Snap-On or Cornwell but the jack does the job and for a hell of a price.
      02-03-2016, 01:21 PM   #17
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Same here with the HF aluminim jack, which I've had for probably 7 years with no problem and lots of track tire changing duty. Don't get the cheaper ($80) one. Get one of the larger, wider ones that normally go for $150 or so, but are frequently on sale for less. The rapid pump feathure is decent too.
I've had the smaller ones twist on me, and seen probably a dozen twist on others.
      02-03-2016, 01:50 PM   #18
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
I have the Harbor Freight Aluminum 1.5 Ton one. It's small and light so easy to carry around and use. I have seen some twist. It comes from jacking up the car at an angle where the car rolls or moves. If you take care to jack up at an angle where the jack can move with the car as it goes up, there is no twist.
I find I rarely need to use any more lifting capacity when working on most cars. I live in an apartment so the portability is a big deal to me.
Auto Detailing Enthusiast!
      02-03-2016, 03:25 PM   #19
Ric in RVA
Bergspyder
Ric in RVA's Avatar
Drives: '11 BMW 128i Sport 6mt
Half the time someone is pissed at a jack it needs bleeding.
Most of them are bled by turning the handle like you are lowering the jack and then a few turns past and pump slowly 10 times. Check your level and add hydraulic fluid. Repeat.
Makes a difference!!!
Ric in RVA
2011 128i 6 MT Sport, 2009 Cayman 987.2, 2011 528i N52, 2018 F150 Platinum
      02-03-2016, 07:13 PM   #20
nholmes
Track Whore
nholmes's Avatar
Drives: women wild
I have the HF aluminum jack I've used around the house and at the race track without issue for about three years. The fact that it's light weight is great.
The key to longevity is to not abuse it and don't leave the cylinder locked in the closed position.
Originally Posted by ridinwide View Post
Even though you answered my PM like you're missing a chromosome or have some other issues I still want these.
      02-03-2016, 07:21 PM   #21
bodega_bladerunner
Drives: 2015 M4
another +1 for the HF 3 ton low profile jack!
      02-28-2016, 09:21 PM   #22
Apex Everything
Drives: M3
I honestly am surprised everyone is mentioning getting a Harbor Frieght jack. I was taught they provide the lowest of low in quality.
