      01-11-2013, 04:47 PM   #1
headleeb2000
Drives: x6 idrive
Engine malfunction reduce power
Frustrated with this going into shop for the 6th time in 1 month. Is this normal?
      01-11-2013, 04:54 PM   #2
Oscar-ur
Drives: BMW 335 Coupé -10
Which model?
      01-11-2013, 04:57 PM   #3
headleeb2000
Drives: x6 idrive
2009 X6 50i xdrive 33,000 miles
All they have done is change injectors and spark plugs
      01-11-2013, 10:06 PM   #4
ifly
Cruising!
Drives: 2017 X5M
Ask them whether the HPFP has been changed! Should have been a warranty recall.
      01-11-2013, 10:46 PM   #5
evandro13
Drives: 2012 BMW X6
lemon law
      01-12-2013, 04:06 PM   #6
crunchingnumbers
crunchingnumbers's Avatar
16
Drives: 2022 X6M, 2018 RRS
high Pressure Fuel Pump
I was driving my car over New Years when it started sputtering and went to reduced power mode and. I thought it was going to stop altogether. I managed to limp it into my dealer (about 250 miles with few choices).
Anyhow they confirmed that the high pressure fuel pump had failed but also said it was the first failure they had seen on a V8 (Nov 2012 new delivery X6 5.0 now with 29k). I had them do a service and change the tires amongst other things but my high pressure fuel pump was changed within a day. No problems in the last 400/500 miles - 2 days
      01-12-2013, 09:23 PM   #7
Elirseo
Drives: 335xi coupe & f10 M5
So what happened? Did u get a car back and everything was fixed??
      01-16-2013, 10:38 PM   #8
Brian@MWP
Just had a New 7 in the shop same running issues and check engine light on. End result HPFP replacement.
      01-16-2013, 11:31 PM   #9
headleeb2000
Drives: x6 idrive
Car is still in shop. They are still working on it. Just want to make sure that when they say its ready Again we can ask if everything had been checked or what all options could be.
Thank you all for your ideas in experience help. We will post when we find out what they have to say when they think they have it fixed this time.
      01-27-2013, 01:30 PM   #10
headleeb2000
Drives: x6 idrive
They now say it is the injector valve leak.
      01-27-2013, 11:04 PM   #11
awdnut
Drives: 13 X5M
2013 BMW X5M  [0.00]
I thought the dealer already replaced the injectors?
