      07-02-2022, 03:44 PM   #1
kensou
Drives: bmw x6 m
BMW X6 M e71 2011 : black smoke, may long crank when warm, small irregular vibrations
Hi
No error code for the engine after diagnostic
When cold start , start hardly (with pop and bang lol), smoke a lot (gray/black), gray smoke when full load on roads
Fuel pressure regulator ?
Oxygen sensor tired and reading bad value ?
Injectors to be replaced ?
Air filter ?
https://youtube.com/shorts/5bWVbpVvryQ?feature=share
Thanks for your help
Patrick
      08-10-2022, 03:56 PM   #2
525DA_touring
Drives: BMW E88 125i 2007; BMW E70 X5M
I think bad injektors
      08-20-2022, 11:23 AM   #3
kensou
Drives: bmw x6 m
thanks for your reply.
I think so also.
BUt i wanna know others opinions.
because no CEL, no logged error.
Only one time, on a hard throttle on higwhay, after 20 mn of hard drive, i got LIMP mode, et got oxygen sensor voltage value excessive (after cat). and got something like injector issue on cylinder 1.
If injectors are faulty , why i didn't get any error like mixture too rich ?....
      03-01-2023, 02:36 PM   #4
kensou
Drives: bmw x6 m
Just to confirm that the problem is solved by replacing injectors
      06-21-2023, 01:06 PM   #5
1er_vert
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
Use BEST Fuel
The top-tier petrol has the best additive packages. Use the cheap stuff and you will see Reduced Power faults... even after ONE USE!
2007 BMW Z4 3.0si - Hellrot
2010 BMW X6 M - Space Grey
kensou4.50
