      10-08-2018, 01:12 PM   #1
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
X5M H&R 1.2" Springs & Spacers Install
Ever since i purchased my E70 X5M in June 2018 I did not like the stance of the SAV. I kept looking at the Jeep SRT8 at work every day and noticing how good the stance looked for a factory setup.
With the help of so many members here especially boneca , gixxerboy63 , Doctor///M , RDR142 and others i was able to decide on what lowering system to go for on this truck.
I decided on H&R 1.2" Springs, H&R 12mm front and 20mm rear spacers and F10 M5 Comp Bump stops from ECSTuning . ECS went above and beyond to put together the package for me and have it delivered to me within a week of ordering, all the way to Bahrain.
Here are the install pics:
Stock front Shock with stock spring
H&R 1.2" Spring
OE X5M E70 Bum Stop Vs OE M5 F10 Comp Bump Stop
OE Vs H&R Spring
Ready to install H&R Spring and F10 M5 Comp Bump Stop
Installed
OE Vs H&R Rear Adjustable Height Links. These were set to 65mm or so i thought. It turns out they were set to 61-62mm, my mistake. We fixed this later.
Removing rear Shocks and installing F10 M5 Comp Bump Stops, They have to be pressed into the top hats by hand. Im glad i changed these as the old ones were gone from the heat
Jonathan Torquing every thing to spec
H&R 12mm front and 20mm rear Spacers with ECS Extended Bolts:
Before Spacers and lowering springs
Installing Spacers, hubs were cleaned and anti-seize applied
Spacers installed
Finished Pics with both the spacers, springs and bump stops installed:
The rear was too low and as soon as I left the shop the car was bouncing so much and the rear was so hard that it gave me a headache. Went back and adjusted the links properly this time to the H&R specified 65mm and the car drives perfect. Everything is a bit tightened up. This is the way the truck should have come from the factory.
Pic of the before and after height measurements
Sorry I ran out of memory on the DSLR so I will take some updated pics this week and post them up here. Thanks for reading.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
IG: @060Motorsports
      10-08-2018, 02:18 PM   #2
boneca
boneca's Avatar
Drives: 2022 BMW X5
2013 BMW X5M  [10.00]
2011 BMW X5  [10.00]
Looks great and congrats on awesome set up, enjoy
      10-08-2018, 02:19 PM   #3
0-60Motorsports
Bahrain
792
Thanks to you brother.
Current Mods:
IG: @060Motorsports
      10-08-2018, 02:24 PM   #4
pearlpower
Drives: 2013 328i
Looks good, curious how it rides with passengers in the rear or cargo.
      10-08-2018, 02:26 PM   #5
0-60Motorsports
Bahrain
792
Have cargo in the rear but hardly ever or never have passengers in the rear of any of my cars unless necessary lol
Current Mods:
IG: @060Motorsports
      10-08-2018, 03:24 PM   #6
9vapors
Drives: CB X5M
I've seen it a bunch, but can you share the part number for the m5 bump stops please, need to get a set ordered
      10-08-2018, 03:29 PM   #7
0-60Motorsports
Bahrain
792
Four pieces of 31337847472
Current Mods:
IG: @060Motorsports
9vapors651.50
      10-08-2018, 10:42 PM   #8
9vapors
Drives: CB X5M
My rears are the airbags, do they need the bumpstops too? I'm confused as you said you added them to the rear shocks and did the adjustments arms too...
      10-08-2018, 11:39 PM   #9
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
What is the general consensus now? 1.2" drop with the M5 bump stops? I haven't heard of this, guess iv'e been away too long. This eliminates the bone jarring violent bumps when installing HR springs on the X5M? Sounds promising.
The drop here looks perfect.
      10-09-2018, 12:53 AM   #10
0-60Motorsports
Bahrain
792
The Bump stops are not a necessary option according to everyone else but ive installed the bump stops from Dinan on other cars and they work. The Bump Stops from Dinan are not special, they are OE BMW from another model.
If you want a good quality ride and want to prevent bottoming out in certain road conditions get four BWM F10 M5 Comp Bump stops (PN is listed in one of the posts above) and install them with ANY spring kit you install. If you have airbags in the back you'll need to order the appropriate kit suited to your vehicle which will come with two front springs and two rear adjustable links. the rear bump stops go on the rear shocks! the car still has shocks even though it has rear airbags.
Well it depends on what you want, If you want a near OE ride and the perfect lowering for this vehicle i would recommend the 1.2" H&R and Dinan kits. The Dinan doesnt make a big enough difference in height for me to justify it to be honest. the H&R 1.2" kit is perfectly fine and retains OEM ride comfort. With Any spring kit i recommend to install the F10 M5 Comp Bump Stops.
Current Mods:
IG: @060Motorsports
9vapors651.50
      10-10-2018, 05:49 AM   #11
loayoweis
Drives: E46 M3 Coupe - E70 X5 35d
Nice!
      10-10-2018, 05:54 AM   #12
0-60Motorsports
Bahrain
792
Originally Posted by loayoweis View Post
Nice!
Thanks bro, Was in Dayton a few months back
Current Mods:
IG: @060Motorsports
      10-10-2018, 07:40 AM   #13
boneca
boneca's Avatar
Drives: 2022 BMW X5
2011 BMW X5  [10.00]
when I replaced my front shocks (KWs) couple of years ago I got new bump stops from KW, I got 2 sets front and rear, fronts were replaced while replacing the shocks as for the rear I never got to them, still in the box...
btw I was replacing KWs with KWs as coilovers were already on the car at the time (first owner beat the crap out of them in NY!)
      10-10-2018, 07:46 AM   #14
0-60Motorsports
Bahrain
792
Good info. installing the rear shocks are easier LOL
Current Mods:
IG: @060Motorsports
      10-10-2018, 03:25 PM   #15
Vitalität
Vitalität's Avatar
Drives: BMW i3 & X5
2015 BMW i3 BEV  [0.00]
2007 BMW X5 48i  [0.00]
2006 BMW 330i  [0.00]
2004 BMW 330i  [0.00]
Looks so much better! I have the H&R 2.0 and hopefully it will not be too low when I install them.
Garage: BMW i3 Giga World BEV | BMW E70 X5
      10-11-2018, 12:25 AM   #16
0-60Motorsports
Bahrain
792
Well hope you got the bump stops to go along with that kit because it might be bumpy. get the bump stops, your gonna need them.
Current Mods:
IG: @060Motorsports
      10-11-2018, 12:10 PM   #17
Vitalität
Vitalität's Avatar
Drives: BMW i3 & X5
Yeah thought about that. Go the part numbers and thank you! Right now, this is how my X stands...
      10-11-2018, 12:12 PM   #18
0-60Motorsports
Bahrain
792
Get her lowered
Current Mods:
IG: @060Motorsports
      10-11-2018, 12:52 PM   #19
Vitalität
Vitalität's Avatar
Drives: BMW i3 & X5
Get her lowered
The bump stops are good for non M models right?
      10-11-2018, 01:49 PM   #20
0-60Motorsports
Bahrain
792
Get her lowered
Yeah they should be
Current Mods:
IG: @060Motorsports
      10-11-2018, 02:49 PM   #21
do_0b
Drives: 2010 X6 M
2010 BMW X6M  [0.00]
whats mm spacers are you using?
      10-11-2018, 03:01 PM   #22
Vitalität
Vitalität's Avatar
Drives: BMW i3 & X5
H&R 20mm front and 25mm rear. Im doing front only though.
