07-07-2016, 06:29 PM | #1 |
Rep 162
Dyno Results
I brought my M in today to get a few pulls on the Dyno Dynamics and was pretty disappointed to say the least. Tune or no tune I put down ALOT lower number than I thought it would. Best run was 408 HP and about 490 ft lb TQ. I was told and have seen in other posts that Dyno Dynamics is very safe and lower than the Dyno Jet but from what I've seen it's supposed to be most accurate and similar to the Mustang Dyno. I already have an appontment to bring it back in to have a few more pulls with stock ecu instead of the Velos tune to see what the difference was.
Velos Stage 2 + Tune , Fabspeed Supercup Exhaust, Active Autowerke downpipes
07-11-2016, 08:08 AM | #2 |
Rep 1,701
Not sure if this is because you have DPs (I don't), but mine was only whistling that loud at WOT when I had a boost/vacuum leak from a crankcase ventilation hose (the Connecting Line, to be exact - #3 in the link below)...
Vehicle was definitely loosing power up top but no error codes were thrown... Could be why you're putting down lower-than-stock numbers, while tuned. I'd check for oil residue on that bridge that guides the hose from one side to the other... Unfortunately, it's impossible to check the two lines being connected since they are pretty buried on the sides...probably would have to get it smoked to test those for leaks... http://www.realoem.com/bmw/enUS/show...diagId=11_4291 |
07-11-2016, 09:20 AM | #3 | |
Rep 318
Thats the dyno, not his turbos.
07-11-2016, 09:43 AM | #5 |
Rep 162
Thanks for the feedback and will try to look into it.
07-26-2016, 04:44 PM | #7 |
Rep 813
how many miles do you have ?
new injectors ? plugs replaced every 30k ? if more than 80k miles may be need walnut blasting ? but that does seem a bit low
Huracán Performante 18- Novitec Springs | RR SVR 19 | G05 X5 M50i | E70 11 X5M retired |
Jerez Black E92 10 m3 RE SSK | AFE Filter | Fabspeed XFC / Xpipe | AA ECU 1.5v | BMW PSW | Envy Charger | Megan Exhaust |
07-27-2016, 07:16 AM | #8 |
Rep 131
I wouldn't get too hung up on the numbers just yet. Did you ever baseline your truck stock as a comparison to your tuned/modded numbers? I personally like to tune on a Mustang/Dyno Dynamics dyno as they are load bearing dynos and allow you to fine tune different areas of the map under different load conditions, whereas, most Dynojets don't have eddy current brakes to simulate load. I have found that most Dynojets read about the same from shop to shop as there are less variables that can be modified. Take the truck to the drag strip if you like and compare to what others are running. My personal best was 12.2 @ 112 and think it may have a little more in it with cooler weather.
2012 Alpine White X5M (500whp / 577wtq) - Eurocharged Tune, Agency Power Downpipes, Gintani Exhaust, K&N Filters
