The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Titanium Exhaust Wrap, what's the real truth?
      10-09-2014, 03:51 AM   #1
Scotty89
Buy a 335 they said... It'll be fun they said...
Scotty89's Avatar
Australia
117
Drives: 2007 E92 335i
2007 BMW 335i  [10.00]
I've ordered some VRSF downpipes, and I thought that it would be easier to wrap them before installing (obviously).
I've tried searching however and there seems to be very little threads about exhaust wrap, and of the few comments that I could find people were saying the wrap is a bad idea as it creates a moisture environment that will rust the downpipes??
First, on a forum where nearly everybody gets downpipes of some sort, I can't understand why this topic seems to be so scarce?
Second, I can't understand why there should be moisture causing rust on the downpipes? The heat should keep them dry and evaporate the moisture, and I don't live near snow. Any rain or wet roads shouldn't splash water up there due to the belly pan.
My engine bay gets really hot at present, and I've got nothing but a JB4. Everything else is standard, so I though wrapping the new downpipes would be a good idea to help prevent even higher engine bay temperatures.
Is this really a bad idea??
      10-09-2014, 03:59 AM   #2
SPJ
SPJ's Avatar
10
Drives: 2007 335i
good idea ! only issue I can see is you might restrict the clearance b/w dp's.
Moisture issue is more related to cars that see allot of water underneath, ie 4x4 etc
      10-09-2014, 04:46 AM   #3
donlokiman
Drives: 2011 335i E92 LeMans Blue
I'm looking at downpipes and a friend suggested I wrap mine as well.
      10-09-2014, 04:51 AM   #4
donlokiman
Oh whether or not his suggestion was a good one or not I do not know. But you aren't the only one considering it.
      10-09-2014, 05:01 AM   #5
Ingeniator
Ingeniator's Avatar
Drives: 07 335XI(90) 09 135I(82)
Downpipes may be alright but headers will likely crack as a result of wrapping any place that has salt(Ocean air/ salt on roads etc). The salt is exposed to metal via water when the water evaporates it leaves the residue which is going to lead to stress corrosion cracking. Just be aware of the problem and periodically check and clean the wrapped part.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system
      10-09-2014, 07:36 AM   #6
stanlalee
Drives: 07' E92 335i manual
I think many have moved to coatings over wraps which I think VRSF and perhaps others offer.
      10-09-2014, 07:56 AM   #7
shadow191
Drives: 2017 Volvo XC90 R-Design
Back in the day, people wrapped headers and some of them cracked or rusted out due to moisture. But keep in mind that back then a lot of cars didn't have extensive splash shields like most cars these days. Instead of a full belly pan, you had a couple of small covers in front. Headers were often exposed. So what was a problem back then may not be a problem now.
And I think all aftermarket downpipes for the N54 are stainless so rust isn't that much of an issue. Other than a little surface rust, SS isn't going to rust through. Unless they use a really low grade.
Coatings are good, but I think the wrap does a better job in terms of heat transfer.
      10-09-2014, 07:59 AM   #8
FCobra94
Guest
n/a
Drives:
Agreed. I'd rather go that route anyway.
Looking forward to Tiago's thoughts/test results on the subject
      10-09-2014, 08:14 AM   #9
JamesM3M5
Some dude
Drives: E92 335i
Coatings go a long way toward reducing under hood temps, but don't count on it to drop like crazy since the turbos are the main heat generators. The manifolds are double walled to reduce heat loss before the turbine, but once they hit the turbine housing, that heat just radiates. Cats that close under the engine definitely don't help the situation, so coated DPs should still net a heat reduction benefit.
If you have new parts, Jet Hot can coat them - they don't do used parts since they don't stick as well. Swain Tech coatings are good, but I've seen too many flake off on NA racecars. Swain may be more durable on parts that don't see long periods of high heat.
My vote is for coating versus wrapping. Coatings go inside and out, where wrap is outside only.
RRT
E92 335i/6MT with stuff and things
      10-09-2014, 03:47 PM   #10
Petrolhead3010
Petrolhead3010's Avatar
Drives: 2021 BMW X3 M40i
How would someone do a proper coating on the inside of the piping? I've thermal coated the outside of my exhaust manifold, but never thought to do the inside
      10-09-2014, 04:33 PM   #11
Mixmaster
New Zealand
28
Drives: 335i E90 N54 / 2014 i3 REX
Very little room around the pipes when installed. May touch with wrap on
      10-09-2014, 04:38 PM   #12
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Proper thermal coatings are generally always better at trapping heat than wraps.
      10-09-2014, 04:50 PM   #13
07tundra
Drives: 8.1L Chevy 2500hd
exhaust
How about that new exhaust
2008 335i FFTEC ST 6266,), Boostbox, VRSF 3.5 exhaust, mtech front and rear, KWVll, APEX 18x9.0, 18x12= 305/35/18 NTO1s, BMS OCC, Rb PVC, M3 tri-color stitched S-wheel,MT SWAPPED, M3 LSD diff
2008 135i mods coming soon!
      10-09-2014, 04:51 PM   #14
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Expecting the latest production sample in within the next 2-3 weeks
Longest process ever.
      10-09-2014, 06:04 PM   #15
Eat.Sleep.Race
Out Boosting...
Drives: F30 335i M-Sport
Don't really need to do it, it can cause cracking due to so much heat being held in, Id recommend JET-HOT coating, as thats what all the race cars, and fast street cars use. Cost is around $100-150 for 2 downpipes.
Alpine White M-Sport F30
      10-09-2014, 06:14 PM   #16
cmg5461
Drives: 2008 Deep Green 335xi 6MT
2008 BMW 335xi  [0.00]
SS rust is clear from the chrome - what looks like rust is just tarnishing from heat
      10-09-2014, 06:48 PM   #17
3000GT MR
3000GT MR's Avatar
Drives: 09 335i/3000gt vr4
I can't wait. José you need to buy one. Sounds so good with single
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust
335i 2009 e90 665RWHP VFF900 ST RIP .
Tags
exhaust, exhaust wrap, titanium wrap, titanium wrapping
