09-09-2014, 11:36 AM | #1 |
Rep 29
Drives: 2012 135i Blue/Tan Nav/M/HK
1st oil change at 28K! - should I be worried?
Hello, I just purchased a 2012 135i with 28K miles on it. I took it to the BMW dealer and pulled up the service history. It appears that the 1st oil change was done at 28K! Usually 1st change should be done around 14K.
Should I be worried about this? I am planning to keep this car for long. But worried about damage to engine. Thanks in advance (noob to 1 series & BMW overall) |
09-09-2014, 11:47 AM | #2 |
Rep 101
I'm no expert by any means but aren't the first oil changes the most important for the engine? I'm not sure what damage(if any) would occur if it misses the early interval.
09-09-2014, 11:53 AM | #3 | |
Rep 1,026
09-09-2014, 01:54 PM | #4 |
Rep 2,276
I think no damage. Car is a 2012; its under free maintenance-BMW dealer should have changed the oil in 2013 (after 1 year in service) or earlier if onboard CBS says to. Suggest your car was likely used a lot on highway, hence CBS let it go this long. Most of us with new cars get the free once a year BMW dealer oil change then do a second ourselves 6 months later. Oil changes are not too difficult.
09-10-2014, 12:57 AM | #5 | |
Rep 704
It's possible, although not likely, someone else changed the oil, even though BMW provides free maintenance. Maybe they lived too far from a dealer? Of course, the question is, if the first oil change was at 28K, what would you do about it? |
09-10-2014, 03:59 AM | #6 |
Rep 29
Ok here are pictures of the oil cap. lots of sludge on the outside but engine appears to look clean inside?
This cars was sold in Seattle originally and driven for 2 years, and eventually transferred to Southern California for me. Purchased through CarMax. I will obtain the CarFax tomorrow and also have CarMax do another inspection. Oh btw, I picked up my car last Friday evening and drove it home... Saturday morning I noticed a coolant leak (blue) on my garage! Not even a day! ... Took it to BMW dealer since its still under warranty. It was fixed and turned out to be the headlamp washer fluid. They replaced the nozzle and pump. This is where I found out about the 1st engine oil change. I just received the car today and absolutely love the looks and the drive. Deep Sea Blue Metallic, Two-Tone Leather Tan interior (with black). M Pkg/Prem Pkg/Harman Kardon Sound. Thoughts? |
09-10-2014, 05:59 AM | #8 |
European Editor
10539
Rep 22,992
moral of this story... don't buy a car from Carmax. lol Seriously... I was going to say the owner could have been changing his oil on his own or going to an indo shop. But that sludge on the oil cap is worrying. IF I were you... and you still intend to keep the car for a long time... I would pull the valve cover off the engine and have a look. Or maybe you could borrow one of the endoscope/cameras and have a look thru the oil cap.
In the very least, I would change the oil a few times(two or three times) in the next thousand miles to purge all the sludge crap in the engine. Be sure to change the oil filter and use a BMW bought filter with LL1 approved oil. And buy a new oil cap, bc a pooly sealing oil cap can cause a vacuum leak and rough idle. Its not that much for a new one.
09-10-2014, 06:35 AM | #9 |
Rep 1,026
I don't see any sludge build-up in your engine, which is a good thing, but I agree with Dack, I would change the oil a couple of times in the next 1-2,000 miles to make sure the engine is cleaned.
What does the oil filter and area around it look like? |
09-10-2014, 08:43 AM | #10 |
Rep 29
Awesome thanks for the advice.
The engine is squeaky clean since carmax cleans them so they look nice. It's hard to know how it looked like before. Where should I look at or what should I open and take pictures of? |
09-10-2014, 08:59 AM | #11 | |
European Editor
10539
Rep 22,992
IF you really wanted to dissect you old oil filter you could cut it apart like this... clean oil flows from the inside to the outside of the filter. You do not want your filter looking like this sludge horror... PS: also do not use any engine oil cleaners or additives. Just change the engine oil a few times in a short mileage interval.
09-10-2014, 09:33 AM | #12 |
Resident Tamed Racing Driver
298
Rep 4,697
Wrong side of the engine.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
09-10-2014, 12:33 PM | #13 |
Rep 29
Ok, I'll keep you guys posted, they are going to do another full inspection and also look inside the engine for sludge build-up.
09-10-2014, 01:34 PM | #14 |
Rep 722
Yes i would be a little worried if there is any liquid oil left in the car. Do a few short interval oil changes and you should clean the engine out.
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
09-10-2014, 04:55 PM | #15 |
Rep 29
Ok, they did an inspection with the camera inside the engine, no sludge build-up. They did find some other transmission leak and its going back to the bmw shop.
Oh and btw, the AC panel went out today morning, completely, not a single button was working! Its repaired now, apparently a blown fuse ... WTH! |
09-10-2014, 10:50 PM | #16 |
Rep 4,686
Drives: L'Orange
i'd consider returning the car to Carmax. they have some sort of return policy right?
IMO the maintenance history should have been the FIRST thing you looked at when buying a used car. Because you didn't-----you may get stuck with some issues further down the line that can't be fixed no matter what you do now. |
09-10-2014, 10:54 PM | #17 | |
Admiral of the Fleet
265
Rep 3,551
09-11-2014, 10:53 AM | #18 |
Rep 195
I believe I would have looked at the service history before I bought the car. While extended oil intervals are OK, 28K is over doing it. In general, BMW & MB along with most of the industry now recommends oil changes every 10K or once a year whatever comes first.
Actually the problem really isn't the oil but the filter. Oil can be used well beyond 10K if the filter is changed. |
09-11-2014, 11:38 AM | #19 |
Rep 1,026
You got that backwards. Quite often an oil filter can outlast the oil. In fact, Honda recommends replacing the oil filter every other oil change on many of their models. Good synthetic media oil filters can go 15,000 miles between changes.
09-11-2014, 12:57 PM | #20 | |
Rep 195
Oh balderdash!
There is nothing wrong with extended oil changes with modern lubricants. Oil doesn't break down over time. The problem is the build up of contaminants over relatively short intervals. If the lubrication system can effectively remove them, oil can be used almost indefinitely. I suspect BMW would like to do what Honda is doing or change just the filter every service interval and the oil every second. The problem would be all the gear heads would be screaming about the company trying to destroy their engines to make money selling parts or some such nonsense. If you read car forums, you find a group of people who want to flush and refill everything imaginable. The third member never needs any service assuming it was properly filled by the factory. The same is true for manual gear boxes. They aren't subjected to the products of contamination that an engine is. About the only problem they have is moisture which is dissipated on warm up. Also they are filled with synthetic lubricants. Makers today are taking advantage of great advances in engine and lubrication technology to build products that require less attention by consumers. Take for example, that yellow colored radiator coolant. That's a long life coolant that designed to protect the aluminum parts of your engine and give a long life service usually 5+ years. Even brake fluid doesn't usually needs to be changed depending upon its level of moisture. Some brake fluids aren't affected by moisture. There is on item that may need attention, and that is automatic transmission. The problem here is depending upon internal wear it may need a filter and oil change. I figure most of you will never keep the car long enough to really concern yourselves about all this flushing and refilling. I keep vehicles at least 10 years, so I am concerned about NECESSARY service to prevent expensive repairs. |
09-11-2014, 01:21 PM | #21 | |
Rep 1,026
Also, the base oil does not break down, but the additives do break down. You need to change the oil when the additives break down (TBN <1.0 and TAN >> TBN). And by the way, I plan on keeping my car 10 years or more. Last edited by Iron Man; 09-11-2014 at 01:31 PM.. |
09-11-2014, 03:59 PM | #22 |
Proud AARP member in good standing
28
Rep 635
Goes to show don't trust CarFax. They had my Speed 6 as airbag deployed and needed a tow when I had a low speed fender bender that was all of $1200 damage on my car. New front bumper cover, license plate bracket and a buff of the headlight fixed it. Dealer pulled the Carfax and said my car was unsellable and low balled me when I went to trade it in. I showed them the pics I took of the damage. Damn NC cop checked too many boxes on the accident report. Hell, I drove it from Charlotte to Sebring and back to OH with the damage and both headlights functional.
Oh, and good luck with the oil. First thing I do is ask for the service history from the dealer. I questioned the BMW dealer I bought mine from and they said it had all maintenance performed. It didn't. So much for CPO.
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver. |
Tags |
135i, engine fault, maintenance schedule, oil change |
