      08-28-2020, 04:29 PM   #1
rod.bearings
rod.bearings's Avatar
Drives: E92 M3
2009 BMW 135i  [0.00]
Vrsf downpipes, do these fit 2010 x5m?
Not sure what these came off of. But guy said x5m but pictures look different
2011 E92 M3 AW DCT
IG - rod.bearings
      08-28-2020, 05:15 PM   #2
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
No, these are slip on style. You need the bolt on style for the e70 x5m.
      08-28-2020, 05:18 PM   #3
Autobacs
Autobacs's Avatar
Drives: 2019 BMW X6M
Even with the right VRSF downpipe for the X5M, they don't fit right, unless they have modified them. There you go, I have warned you.
2019 BMW X6M
2013 Lexus RX450H
2010 Nissan GTR AMS Omega 14
      08-28-2020, 06:29 PM   #4
Dawgz
2022 M4 Comp Xdrive
1016
Shots fired 😂
      08-28-2020, 07:12 PM   #5
Autobacs
Autobacs's Avatar
I'm doing everyone a favor. Do it at your own peril LOL
2019 BMW X6M
2013 Lexus RX450H
      08-28-2020, 07:25 PM   #6
rod.bearings
Drives: E92 M3
Lci is slip on. I found out these are from 550i and should fit. If not I'll make it fit.
And yea all n63 are a pain in the ass and it seems bmw changed the style a few times
2011 E92 M3 AW DCT
IG - rod.bearings
      08-28-2020, 07:29 PM   #7
TwinSnailz
TwinSnailz's Avatar
75
Drives: 2011 X5//M
Probably going to need to weld it on the exhaust because the slip on ends are not even tapered down to slip inside.
      09-02-2020, 03:07 AM   #8
danzio2020
Drives: X6M
Ok so long story short I made these fit into an E70 X5M using the factory slip fit connection on the exhaust.
Long story. E70/E71 X5M and X6M are two bolt flange style downpipe. I’m convinced that’s the case regardless of build date as the 2013 I put these in had a flanged downpipe. At some point BMW decided to add a slip fit exhaust connection portion (about 6-8 inches after the exhaust flange) to the E70/E71 M’s, however the downpipes are still a two bolt flange style.
Getting these to fit required cutting/grinding off the bracket into which the flanged downpipes go into. What a pain in the ass. Once the bracket was cut off the downpipes fit like a glove into the factory exhaust where the slip connection and exhaust clamp are.
If you are considering downpipes for your E70/E71 X5M or X6M check for the flange portion. If it exists like it does on my 2013 then you must use flanged style downpipes regardless if the slip connection exists at the exhaust, or you’re in for a headache.
