      12-02-2019, 10:47 PM   #1
SgtFreako
SgtFreako's Avatar
Drives: BMW X5M
E70 X5M Part in Question
Hi all just wondering what is the part that is behind black grill circled in yellow
      12-02-2019, 11:22 PM   #2
pdX5M
pdX5M's Avatar
Drives: E70 X5M
2013 BMW X5 M  [0.00]
Believe that's an "additional water cooler". Here's some info on how to remove it if you need to.
https://www.newtis.info/tisv2/a/en/e...parts/KW858393
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
      12-03-2019, 10:31 AM   #3
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Like pdx said, that's an additional radiator for your engine, on the passenger side there is another and that's the engine oil cooler, then in the front you have the two radiators for the intercoolers, then your power steering radiator, then your actual engine radiator and beneath all that is your transmission cooler. Your ride has no less then 6 Radiators/heat exchangers and five water pumps! It's a bit complicated making a 5300lb SUV as fast as most sport cars
      12-03-2019, 04:36 PM   #4
SgtFreako
SgtFreako's Avatar
Drives: BMW X5M
K thanks for the information
      12-03-2019, 04:37 PM   #5
SgtFreako
SgtFreako's Avatar
Drives: BMW X5M
Good lord, this vehicle is definitely not simple.
      12-03-2019, 04:39 PM   #6
SgtFreako
SgtFreako's Avatar
Drives: BMW X5M
Is there any picture information regarding these parts??
      12-03-2019, 09:50 PM   #7
pdX5M
pdX5M's Avatar
Drives: E70 X5M
These two websites are something you should definitely bookmark. You can find what you're looking for on one of these:
https://www.realoem.com/bmw/enUS/par...2-E70-BMW-X5_M
https://www.newtis.info/tisv2/a/en/e70-x5-m-sav/
      12-06-2019, 08:20 AM   #8
philly42
Drives: X5M, Z3M
This has a breakdown and description of the updated version of our engine. The design is mostly the same other than MAF and CCV system.
pjfox2336.00
      12-06-2019, 12:29 PM   #9
pdX5M
pdX5M's Avatar
Drives: E70 X5M
Nothing attached to your post brotha
      12-06-2019, 12:54 PM   #10
philly42
Drives: X5M, Z3M
I attached a pdf document.
The link here might be the place where I originally got it from.
https://www.6post.com/forums/showthread.php?t=803495
pdX5M111.50
      12-08-2019, 04:04 AM   #11
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
Actually, the s63 engine in the x5m is more similar to the N63 engine it was based on. The n63tu is the next generation engine, so it has a lot of upgrades not on the s63.
m5james431.00
      12-15-2019, 09:01 AM   #12
Ebtahi98
Ebtahi98's Avatar
Drives: BMW13E70X5M720?hpAudi2003RS66+
2018 BMW  [0.00]
1989/2000/2006/2018 ...  [0.00]
2004 Audi RS6   [0.00]
2002 BMW Z8  [10.00]
Yup - no MAF / direct inlet to turbos .
      08-31-2020, 08:18 AM   #13
Texmexm5
Drives: 2011 X5M
OMG!!! i had no idea! good info
