      02-27-2018, 07:00 PM   #1
chris604
Drives: X5 M
Oil Change on 2010 X5M. fluid black right away?
Hey all! I took my X5 M E70 in to the mechanic to get an oil change, before seeing this thread. And, I realized that the mechanic could actually scam you out of an oil change, since there's no dipstick to check right away if the oil's clean or not. So, 4 days after the oil change, I got nervous, so I found the oil drain plug underneath, and drained a very small amount onto a white egg container(which works perfectly as I can compare the color). The oil to my surprise was very dark brown, almost black! Did I get scammed? Or is the oil supposed to get black right away (4 days later). They supposedly put in a new filter and 8.5 Liters of new synthetic oil. The motor is a 4.4L twin turbo gasoline, NOT diesel. I know I should have checked it right away, but my other car which has a 2L turbo engine, doesn't get black within 4 days. Thanks!
      02-27-2018, 07:12 PM   #2
RichardR0404
Drives: 2013 BMW X5 35D
Oil went black on my 35d right away after a oil change. I can tell you have some good ass high grade egg from those fancy wrappers
      02-27-2018, 07:19 PM   #3
Deftronix
Drives: 12 X5d & 20 X7 M50i
Second what Richard said. My 35d oil goes black immediately even if I let the old stuff drain for a good hour.
      02-27-2018, 07:31 PM   #4
chris604
Drives: X5 M
Ok. Cool, thanks guys. Yep, some expensive eggs they were! But, those are diesel aren't they? I know that diesel goes black right away, but gasoline engines?
      02-27-2018, 08:37 PM   #5
RichardR0404
My diesel has been deleted shouldn’t go black anyway. It still went black after I drove home from my shop
      02-27-2018, 10:03 PM   #6
rbreding
Drives: 328d, 335d, x5d
Shouldn't be black right away on a non-D.
      02-27-2018, 11:26 PM   #7
chris604
Drives: X5 M
Yeah, I was thinking maybe a few weeks to go dark like that..
      02-28-2018, 03:23 PM   #8
Naz24
Naz24's Avatar
Drives: W205 AMG C63 / E70 X5M
How long was it prior to this past oil change? If there was gunk build up it could be cleaning out. I'd get another change done
2017 C63
2012 X5M
SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i
      02-28-2018, 05:57 PM   #9
chris604
Drives: X5 M
Yeah, I was thinking to do that. You mean right away, or in a few months?
      02-28-2018, 08:21 PM   #10
socale39
Drives: 04 545i SMG
This is perfectly normal and there’s no reason for alarm. Oil changes color extremely fast due to a number of reasons, most of it in part of heat cycles and soot.
Changing oil because of color coincides with the myth that it must be dirty/old oil. If you want to change the oil go right ahead but after that oil change I’d be a betting man your “New” oil with be the same color in the same time period if using the same oil.
      03-01-2018, 09:55 AM   #11
Colodano
Drives: 2010 X5M
If you are really concerned, get a test kit and send it off for analysis. You will get all of the info you could ever want on your oil, and a baseline, so that next change you can do it again and see how your oil is performing, and get a good idea of the overall condition of the engine internally.
      03-01-2018, 10:54 AM   #12
Performancedieselpros
Drives: X6 m
This!!!!!
Blackstone is great to work with!
      03-01-2018, 11:45 AM   #13
chris604
Drives: X5 M
Cool. Thanks for the advice!! Would be interesting to find out the engine condition too.
Tags
oil change, x5 e70, x5m
