02-26-2018, 10:53 AM | #1 |
Rep 364
Calling all high mileage X5 M owners
Long term BMW owner here and looking to add a high mileage e70 X5 M to my garage. I've owned two M3s (e46 and currently e90) and have driven extensively (as well as advised) my mother with both her e60 535xi and e70 x5.
I want to add the X5 M to my garage for rainy day/winter duties, dog hauling, and to keep less miles on my e90 M3. I've got a good mechanic that does all the work on my BMWs which makes me interested in a high mileage X5 M. Am I out of my mind? I over maintain my cars and as a result they've all treated me very nicely. There's some good deals out there for 80 - 100k mile 2010/2011s and it's making me want to jump. Let's discuss. If you have horror stories, please mention failure mileage and cost to repair-- make it real for me. oh, here's a pic of my current ride.
2011.75 E90 M3 ZCP, 6sp, Interlagos Blue
2008 E93 M3, DCT, Melbourne Red 2007 E91 328xi Touring Wagon, Jet Black 2007 Audi B7 S4, 6sp, Sprint Blue Sold: E70 X5M, E46 M3 6sp cabriolet, E46 M3 SMG |
02-26-2018, 11:27 AM | #2 |
Rep 323
I also used to have an e46 and e90. Maintenance wise the x5m has been less than the e90 (had 60K on the e90 and 80k on the x5). You dont have to worry about the rod bearing issue that plagues the e46 and e90. What you do need to watch out for:
Injector (index 12) : under call Driveshaft (under recall) Air bags (under recall) Vent pipe (recall) other things: Vacuum pump leaks Oil pan leaks Vent pipe and associated pcv tubes get brittle leak oil Brakes rotors arent cheap (no aftermarket stock rotor replacements) |
ghostofsenna129.50 |
02-26-2018, 02:06 PM | #3 | |
Rep 364
It doesn't seem too terrible as a high mileage candidate. Is there any recommended preventative maintenance routines? Seems like the vent pipe and PCV tubes could be replaced as routine maintenance...
2008 E93 M3, DCT, Melbourne Red 2007 E91 328xi Touring Wagon, Jet Black 2007 Audi B7 S4, 6sp, Sprint Blue Sold: E70 X5M, E46 M3 6sp cabriolet, E46 M3 SMG Last edited by ghostofsenna; 02-26-2018 at 03:11 PM.. |
02-26-2018, 04:17 PM | #4 |
Rep 323
Make sure the recalls are done
02-26-2018, 04:23 PM | #5 |
Rep 70
126,000 here.. things to look out for right away is the power steering pump and full assembly. Usually goes bad around 50-100K, 2k for that Oil leaks def need to check for that. Cost me 3k
02-26-2018, 04:48 PM | #6 |
Rep 364
How about suspension? Seems like 100k is the right time for shocks and any rubber/moving bushings.
Brakes? Obviously dependent on the type of mileage (highway vs. city), but I assume more often with the weight of the X5 M. Say every 50k miles?
02-26-2018, 05:52 PM | #7 |
Rep 323
Haven’t hit 100k. The rear airbags will probably leak by then. Also you will need a battery most likely. They last about 25/30k
02-26-2018, 10:13 PM | #8 |
Rep 70
I did replace my rear bags at 100K, 700 for both and front suspension needed new rubber cost me 2k dealer install
02-26-2018, 10:14 PM | #9 |
Rep 70
02-27-2018, 08:11 AM | #10 | |
Rep 364
What mileage did you purchase it at? Roughly how much in repairs and preventative maintenance have your performed over this interval? Fortunately, I will have two cars so willing to accept higher risk. Am curious if this could be reliable enough for road trips, etc.
02-27-2018, 08:31 AM | #11 |
Rep 323
Has your X5 M left you stranded before? Yes: Coolant expansion tank crack
What mileage did you purchase it at? 67K Roughly how much in repairs and preventative maintenance have your performed over this interval? $3500 in year 1/2 Fortunately, I will have two cars so willing to accept higher risk. Am curious if this could be reliable enough for road trips, etc. Id be comfortable w a road trip if it had a full size spare. No spare w the car and i dont use run flats. Last edited by jcm3; 02-27-2018 at 08:32 AM.. Reason: spelling |
02-27-2018, 09:23 AM | #12 |
Rep 303
Im not that high mileage on mine but i feel like im getting up there pretty quick i bought mine at 67k in june 2017 and now im at 84k.
I have had to changed one airbag about a month or two ago and now the other side has a leak. I should've changed both at once but i decided not to. The airbags are super easy to but the part is 300/each for oem which is what i go with for that. So far i had all the recalls done and have not had any major issues yet (knock on wood). I do daily it and i took it down to florida one month after i bought it. I can let you know i was first doubting it but after i took it down it was the best experience since i had fun on some highways with it in florida. Its comfortable and i had two other people in my car including our luggage which my gf and her friend had tons of bags but surprisingly it allfit well. I bought warranty for it but now im kind of thinking i should've just saved that and used it for something else. I would say go for it, i dont think you will regret since you already have other cars as well, so it wont be bad if one day its out of commision for repairs. |
02-27-2018, 09:27 AM | #13 | |
Rep 7,489
If you have summer tires mounted...don't expect a very good driving experience when the ambient temps dip and remain below 45° F...and when you start throwing precipitation into the equation (rain/snow/sleet/ice/etc)...the experience can become even worse. If you live in an area where the roads get plowed/salted/sanded quickly & regularly...you may do okay with all-seasons...but again, the lower the ambient temps drop and the more winter precipitation that's thrown into the scenario...the less capable non dedicated winter tires become. To get all you can get from the X5M's AWD technology...dedicated winter tires would be something to truly consider adding to it's arsenal...again, this is if the X5M is to be your winter "turn-to" vehicle. It's not just about traction to take off...but about the ability to turn (without sliding off) as well as braking. For example...the pics below are from a TireRack video (can be found on YouTube) where summer/all-season/winter tires are tested on an ice skating rink: {braking distance when stopping from 10 MPH} {cornering compared while traveling at 10 MPH & negotiating a turn} {accelerating from 0 MPH to reach 60 ft} Last edited by Qsilver7; 02-27-2018 at 10:18 AM.. |
02-27-2018, 09:35 AM | #14 |
Rep 291
For those X5M with high miles, have you replaced the transmission and differential fluids?
A BMW tech mentioned that the shocks are robust and tend to last long. I plan to have mine rebuilt soon after 100k. Look into replacing rubber suspensioncomponents around 70k. |
02-27-2018, 11:05 AM | #15 | |
Rep 364
02-27-2018, 11:18 AM | #16 | |
Rep 364
All good info here, guys. Gives more confidence in this purchase. A candidate I am looking at has 90k miles.
2008 E93 M3, DCT, Melbourne Red 2007 E91 328xi Touring Wagon, Jet Black 2007 Audi B7 S4, 6sp, Sprint Blue Sold: E70 X5M, E46 M3 6sp cabriolet, E46 M3 SMG Last edited by ghostofsenna; 02-28-2018 at 06:34 AM.. |
02-27-2018, 03:31 PM | #17 |
Rep 7,489
02-27-2018, 04:01 PM | #18 |
Rep 291
I’m considering rebuilding because of price and the customization for aftermarket lowering springs. The rebuild could include valving to match aftermarket springs. It’s common to hear people complain about the ride quality or struts failing after installing lowering springs. Matching the components should help eliminate these issues.
02-28-2018, 06:24 AM | #19 | |
Rep 364
Based on my learning from this thread (thank you all), I will be installing lowering springs when/if I have a rear bag leak and suspension refresh. Seems like a great mod to do while in there doing maintenance and an alignment. I have H&R sport springs on my M3 and absolutely love the drop. It is how the car should have came from the factory.
2008 E93 M3, DCT, Melbourne Red 2007 E91 328xi Touring Wagon, Jet Black 2007 Audi B7 S4, 6sp, Sprint Blue Sold: E70 X5M, E46 M3 6sp cabriolet, E46 M3 SMG Last edited by ghostofsenna; 02-28-2018 at 06:33 AM.. |
02-28-2018, 09:40 AM | #20 | |
Tanzanite Blue II X5M Pilot
1047
Rep 2,023
Drives: M3, M4, X3 M40i, X5M
Keeping these fluid clean and fresh is highly recommended for the longevity of any vehicle, especially high performance ones like our X5Ms Recently changed my fluids at 85k miles (all were pretty dirty); -Transmission fluid (filter, gasket ATF fluid, pan bolts) -Transfer case fluid -Front diff fluid -Rear diff fluid - we have a 3 piece differential; (rear diff gear oil + final drive gear oil) -Engine Oil - LiquiMoly 5w-30 I also accomplished some other things while it was in the shop... Installed wireless phone charger in console, reconnected vacuum actuator for exhaust flaps (I have been chasing this issue since I bought it ) The actuator unit was completely bypassed, causing flaps to stay open all the time - I know some of you want to have them open all the time, but not me; I like having the ability to control them when I want! Total cost $1887.00 |
03-01-2018, 09:38 AM | #21 |
Rep 291
I like bypassing the exhaust flap. Though my car is stock...Yours is on a whole new level. |
03-07-2018, 02:13 AM | #22 |
Rep 31
