      08-10-2018, 06:45 AM   #1
Erie Von Otto
DT///M
Erie Von Otto's Avatar
Drives: 2014 F31 Touring
Leak through the overhead light
Has anyone had this issue? It's an E70 3.0 2010. Every time there is a hard rain or whenever I use the pressure washer at the car wash it leaks. Sometimes more than others. Is there a clogged drain somewhere or an open seal? Any guidance would be greatly appreciated!
"With great power comes great responsibility." -El-Superbeasto
      08-23-2018, 09:42 PM   #2
Capnhook
Capnhook's Avatar
Drives: 2012 X5 35d
Clogged front drain in your sunroof. Two run forward thru the A pillar and out in front of the door body structure between the front wheel and door frame. Two more run rearward out the upper hatch area.
      08-30-2018, 05:20 PM   #3
Erie Von Otto
DT///M
How would I even start to access that?!?
      09-01-2018, 08:50 AM   #4
pjfox23
Drives: X5 35i, X5M
Check the wheel wells; there should be a cap for access.
File Type: pdf SIB 541208 Water Leak from the Front of the Sunroof.pdf (31.8 KB, 650 views)
      09-03-2018, 11:41 PM   #5
Glim
Drives: 2006 330i & 2013 X5 35i
Might also be an issue with the front windshield leaking. This happened on our last vehicle. We the same issue with water leaking from the top center console.
Do a soap test where you take soap on a wash mitt and you go all around the window and then you turn the heater blower on high defrost. Make sure the windows and the doors are all closed, and when you stand outside, you’ll see bubbles coming out.
Windshield soap test is from this site:
https://blog.nationwide.com/windshield-leaking/
      09-30-2018, 06:42 PM   #6
Erie Von Otto
DT///M
Windshield was replaced and as of know, fingers crossed, it has stopped... Maybe a seal issue.
