      12-21-2017, 10:34 PM   #1
dreamalaska
Drives: 2013 X6 3.5i
After having my left headlight assembly replaced I needed my headlights adjusted. I researched where the adjusters were located with no luck but was able to finally figure it out. In the attached photo, looking toward the drivers side fender, you can see the two white plastic headlight adjusters. A 6mm Allen key has been placed in adjuster labeled 1. This is the up/down adjustment - clockwise turns the beam higher. The Photo Label 2 is for left/right adjustment. It is deep under the fender and a long handle Phillips screw driver can reach it (but don't mess with it). Since these headlights have up/down and left/right electric adjusters, I highly recommend you DO NOT MESS with the left/right adjustment, and only adjust the up/down in no more than 1/2 turns with the 6mm Allen wrench. Otherwise you will cause the self-adjusters to go haywire and will cause dashboard warnings to trigger!
      12-22-2017, 05:44 PM   #2
peter2772000
Drives: 2012 X6 35i Sport
Always wondered how to adjust them, thx!!!
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
      01-15-2018, 05:10 PM   #3
yco
i'm just saying
yco's Avatar
5731
Drives: E71 X6M '10 (sold)
whats wrong with self adjusting is there a problem with them? and everytime you start the car it doesnt go to default height?
      01-17-2018, 03:57 PM   #4
peter2772000
They go to default on start-up. But if you've dicked with the headlight, you may have thrown the original setting off. Hence the adjustment
2007 FJ Cruiser
2012 X6 35i
2013 ML350 BT
2019 4Runner
