      07-29-2015, 09:17 AM   #1
kong.kham
Drives: 2011 X5
White Smoke!!!
2011 bmw x5 5.0. Some times on start up or acceleration i get a white of puff smoke form the exhuast. What is the problem. Should i be very concern. Thanks.
      07-29-2015, 09:36 AM   #2
hsc1102
Drives: 2010 X5M
Sounds like you may have injector issue that so many have faced.
      07-29-2015, 09:47 AM   #3
kong.kham
Drives: 2011 X5
This sounds expensive!!any one had this replaced before?
      07-29-2015, 09:50 AM   #4
hsc1102
Drives: 2010 X5M
There are numerous posts about the injector issue on this forum, you should search. For the 50i models, there is a recall that BMW is calling a Customer Care Package which should pay for any repairs if you issue is with the injectors/vent valves.
      07-29-2015, 01:08 PM   #5
yoandry
yoandry's Avatar
693
Drives: G80 M3CX & X5 M50i
Hey,
I saw your post about doing the N63 recall, so you should know about it. White smoke is either oil or coolant burning. The recall has to cover this as they did something wrong when putting parts back on the recall. Mine is doing the same white smoke after the recall work was done.
