      01-11-2016, 01:05 PM   #1
DrMattN40
DrMattN40's Avatar
18
Drives: 2012 X5M
Bigger Tires?
I am wondering if I could run 275/45/21 on the front and 315/40/21 on the rear of my M (215 style wheels). Stock runs 285/35/21 and 325/30/21. I'm looking for a thicker sidewall. Any experts out there please let me know what you think the potential issues would be. Thanks
Black on Sakhir Orange Leather with Piano Black trim, Lux Angel Eyes, BMC Air Filters, Fabspeed Supercup Exhaust.
      01-11-2016, 03:23 PM   #2
X Driver
X Driver's Avatar
Switzerland
70
Drives: X5M Black Fire Edition
It is not possible, buy 20's if you want this.
      01-11-2016, 04:17 PM   #3
DrMattN40
DrMattN40's Avatar
18
Drives: 2012 X5M
What makes it not possible?
The aspect ratios are off by the same 2.25mm front and rear as the stock. Overall diameter with wheels and tires for front stock is 28.85" and with the set-up I mentioned the front diameter would be 30.74" (less than 2 inch addition) with nearly identical less than 2" change in the rear. I thought this would be similar to lowering 2 inches. There is definitely enough room in the wells, I'm just worried about the steering mechanism up front or anything else I am not calculating for.
Thank you for the assistance.
      01-12-2016, 08:47 AM   #4
X Driver
X Driver's Avatar
Switzerland
70
They are to big and touch the wheel arc when steering. One more thing, the speedo is not correct anymore.
      01-12-2016, 02:09 PM   #5
serge1
Drives: X5 35d
2011 BMW X5 35d  [0.00]
Adding 2 inches to overall diameter will very likely cause them rubbing against the upper balljoint.
See this thread. A guy installed oversize offroad tires.
      01-12-2016, 04:36 PM   #6
DrMattN40
DrMattN40's Avatar
18
Drives: 2012 X5M
Forgive my ignorance on some of this stuff... isn't adding tire diameters of 2 inches more than stock the same as lowering the vehicle 2 inches with springs on the current size?
The tires I am looking at are regular all-season tires, not aggressive knobby off-road ones. (also, I have 12.5mm spacers up front, 20mm in rear). Thanks for the help.
      01-12-2016, 08:51 PM   #7
Crazy1323
Drives: X5M
Kind of, in your example a 2" increase in tire size would be like a 1" drop. I.e. The top of the tire is one inch closer to the top of the wheel well.
The difference though are items that move in direct relation to the wheel hub like ball joints. When lowering a car, there is no change in the distance from that joint to the tire. The entire assembly move further along its upward travel. When installing larger tires, the distance from those components attached to the hub is now reduced. This will cause the tires to rub on certain components. This is regardless of any amount of lifting or raising of the suspension.
Think along the lines of trying to run a wheel too small to clear a caliper
      01-12-2016, 08:52 PM   #8
serge1
Drives: X5 35d
Lowering has nothing to do with it.
You did say the overall diameter will increase from 28.85 to 30.74.
That may cause the tire to rub the upper ball joint, because the tire sort of goes under the ball joint. This has nothing to do with lowering.
Take a look at the diagram (#2, #3):
http://www.realoem.com/bmw/enUS/show...diagId=31_0786
      01-12-2016, 09:25 PM   #9
DrMattN40
DrMattN40's Avatar
18
Drives: 2012 X5M
Thanks for the clarification. From looking at 275/45/21, with 12.5mm spacers, do you think I can do it, or would I need spacers so wide that it looks ridiculous?
Or do I just lower it 1.2 with H&R?
Thanks again.
      01-12-2016, 09:26 PM   #10
DrMattN40
DrMattN40's Avatar
18
Drives: 2012 X5M
Thanks for the assistance.
      01-13-2016, 07:35 AM   #11
neliconcept
Fashion Photographer
66
Drives: 2013 Porsche Cayenne GTS
spacers would extend the wheels out for sure. It's possible with enough distance from the upper CA, however then you risk rubbing the pinch weld area (corners of the wheel well)
      01-13-2016, 09:25 AM   #12
marblesyrup
Forced induction for high altitude.
Drives: BMW X5M
I had those Nitto Terra Grapplers on my Range Rover and I loved them. Would definitely buy them again. Unfortunately they come in 265/50/20 so if anyone successfully installs them on an X5M with no rubbing I'll order some straight away!
Current: '14 BMW 750XI M-Sport
Current: '16 Tesla Model X
Past: '06 BMW M6 | '03 Ferrari 360 | '02 Ferrari 360 | '08 Audi S3 | '06 Porsche Cayenne Turbo | '09 335i X-Drive Coupe | '08 Range Rover Supercharged | '09 Porsche Cayenne | '11 X5M
