      10-29-2012, 02:23 PM   #1
tgb1974
Drives: 2016 F83 M4 (DCT)
iDrive -- find nearest diesel station?
I may be be demonstrating my ignorance here, but is it possible to have iDrive tell you where the nearest service station that sells diesel is? If so, how is that done, and can I store it as one of my shortcut buttons? Thanks in advance.
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive
      10-29-2012, 11:18 PM   #2
Rosetta Stoned
Rosetta Stoned's Avatar
99
Drives: 2022 M3, 2023 X3
Good question. Is this possible? My 35d is being built still but this also crossed my mind.
MINE: 2022 M3Cx, Sky Grey, Driv/Exec/Park/Laser
1/26 Ordered, 4/26 Prod, 5/4 Assembly, 5/9 Port, 7/11 Transit, 8/3 Port, 8/18 Dealer, 8/25 Delivered
WIFE: 2023 x3 m40i
      10-30-2012, 07:07 PM   #3
midtowneast
Drives: 2012 X5D
1989 325i  [0.00]
2001 330xi  [0.00]
2012 X5 35d  [0.00]
The NAV will not tell you which types of gas a station has. I used a app call gas buddy to find the diesel stations. Another thing to keep in mind is that some stations have truck nozzles that require the use of the adapter an can lead to over fueling.
      11-03-2012, 10:18 AM   #4
No_lines_for_Diesel
Drives: 2012 X5D
BMW Nav does it
Dear All;
The current BMW built-in nav system will allow you to search for stations with fuel type diesel. You only need to set the criteria in the search criteria. Not through Google search, but through the navi Points of Interest.
PS - In the NY area you need not wait in any lines for gas. Just go to a station that has a dedicated diesel pump and ask the cop at the front of the line. I did, got some dirty looks but filled up right away. I will be purchasing a generator soon (for suture need) and it will be a diesel as well.
- No lines for Diesel (in NY area)
