      07-03-2014, 05:42 PM   #1
bux_35d
Drives: 2010 bmw x5 35d
X35 d gearbox issue please help??
Hi guys i just purchased a 2010 bmw x35 d a month ago and i have been noticing that when the gear changes from 2nd to 3rd it jerks and the problem is getting worse?? Any suggestions ?? All others gears are fine its just from 2nd to 3rd going up not down.
Thanks
      07-03-2014, 06:31 PM   #2
blue dragon
Drives: '22 Tesla MY + '23 Tesla MY
Reset the transmission adaptations with INPA, or google it, there is a procedure with the key and ignition sequence and the accelerator
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
      07-04-2014, 04:21 AM   #3
bux_35d
Ok i will search it thanks
      07-05-2014, 11:36 AM   #4
serge1
Drives: X5 35d
2011 BMW X5 35d  [0.00]
OP, did it help?
      07-07-2014, 04:20 AM   #5
bux_35d
Hi mate the op did not help and the problem is getting worse 😢
      07-10-2014, 04:00 PM   #6
note46
Drives: M Coupe, 328d SW, i4
have the same issue with 335d (which I believe uses the same engine/trans combo). the only thing that helped was to replace the transmission filter and fluid. by helped what I mean is that it doesn't feel like someone just rear ended up during the 2-> 3 shift. be prepared for sticker shock if you take it to the dealer for this service...
      10-13-2014, 11:50 AM   #7
P1
P1's Avatar
11566
Drives: 2004 3/4 ton Duramax
Experiencing this myself right now...
      10-14-2014, 04:28 PM   #8
moeenulhaq
Drives: 2011 X5
Try flushing the transfer case fluid and Adaptive drive reset. Problem gone for me
      10-21-2015, 12:19 AM   #9
WULFFZA
WULFFZA's Avatar
Drives: 2011 335i MSport / 2012 X5 35d
Just did this on my 2012 X5 35d..
Bought the car on Saturday and something was off, the car wasn't fluid, I found myself making extra effort to outsmart what I thought the trans was about to do and preemptively adjusted the throttle to smooth progress and shifting.
Before: Trans was dim witted and slow to respond, big lag when tipping in, particularly scary when changing lanes at a crawling pace and trying to get up and go. Coming to a stop there was the feeling of being dragged slower without touching the brakes, like it wouldn't freewheel and downshifted early creating a slight tug. Pulling away then lifting the throttle, eg. to make a turn, would immediately shift to second, with a delay to rethink and downshift again when straightening out and getting on it. When cruising it resisted downshifting when accelerating unless generous throttle was applied. I found myself flooring it frequently to get the right gear. In a nutshell, something was off..
Reset: Put key in ignition, foot off brake, turn ignition on, depress throttle down to kickdown switch and hold for 25 second. Then start car and drive away.
After: So much punch, appears to require less revs on pullaway (don't know how that makes sense), quicker and more intelligent shift pattern, ability to drive the gear selection with modest throttle inputs and lifts. That split second improvement in response has made the car feel so much more sprightly. It just wants to attack the road and fly. Coasting to a stop is smooth with no tugging.
Tomorrow's commute will be a true test.
Happy camper. I can sleep well tonight :-)
2011 E90 335i M-Sport 6MT Alpine white - saddle brown
2012 E70 X5 35d Sport Activity - Alpine white - black
2005 Toyota 4Runner 4WD Sport Edition Silver
