      03-14-2021, 04:59 PM   #1
k5james
Drives: Looking for 35d/335d
AUX Volume issue...
I'm currently installing an AVIN unit in my '13 E70 and am having an issue getting the AUX to work. It shows the level at zero and I'm unable to move it. Any ideas?
      03-14-2021, 09:58 PM   #2
argento
argento's Avatar
538
Drives: 2013 X5M
Do you have monitor connected to aux in? If so, when you unplug the aux, are you able to adjust the setting?
Oh, you should also check the following:
HOME>Settings>Factory>Enter Pin>Vehicle:
Aux Switching Mode: I have mine set to AUTOMATIC
AUX Auto Switching: I have mine set to HARMAN (with a 13 E70, you likely also have the Harman/Becker CIC)
