      03-07-2021, 02:41 PM   #1
Thrawn
Drives: BMW X5
E70 stock boost pressure.
I have a 2013 x5 35i. I installed BimmerLink and BimmerCode. My boost shows 14psi and higher according to BimmerLink. I thought the stock boost was closer to 10. Is there a way to see if the previous owner did some type of tune and what it is? Thanks
      03-10-2021, 05:19 PM   #2
Thrawn
Drives: BMW X5
No one knows this?
      03-11-2021, 02:35 AM   #3
dang2407
dang2407's Avatar
France
9
Drives: 2010 BMW X5 E70 35D MSport
I've been told it gets as high as 3 bar absolute which is 2 bar (29psi). Haven't verified this yet...
      03-11-2021, 11:00 PM   #4
Thrawn
Drives: BMW X5
Ok thanks. Maybe mine is stock then. I thought I read somewhere stock was 9-10 psi.
      03-12-2021, 02:13 PM   #5
Rich807
Drives: X2
General rule of thumb on tons of turbo engines is about 10psi boost per 100hp.
      03-15-2021, 03:53 PM   #6
E-Novo
Drives: 2013 BMW X5 xDrive35i Premiuim
Mine shows the same thing on BimmerLink. I was told that the apps don't compensate for base atmospheric pressure - or something like that. You need to subtract about 14 from the boost number. Cruising on the highway at 80mph - my boost was 16.6... I knew something was up.
If you do a search it should come up. I can try to find it if you can't.
      03-15-2021, 04:12 PM   #7
T-Dubbs
Coal Troll
150
Drives: '14 F10 535d
That's the dumbest thing I've ever read...
A 600hp m5 would run 60psi???
My hybrid burns Diesel & Oil
deleted F10 535d
      03-16-2021, 12:24 PM   #8
Rich807
Drives: X2
Perhaps you missed where I was mentioning a 'rule of thumb'? Obviously it doesn't apply to all vehicles & especially to high performance vehicles like M-series, AMG etc. I've owned a # of diesel vehicles in my life that easily fit into that rule of thumb but glad I could give you a new dumbest thing you've ever heard & a good laugh though!
What's the stock max boost pressure on x5 35i equipped car?
What is it on an E70 x5 35d equipped car?
      03-17-2021, 04:48 AM   #9
Nkponder
Drives: BMW X5 E70
That's not the dumbest thing I've ever heard, haha, but it is not a good rule of thumb.
Stock boost is around 10psi, but can can peak around 12psi. If you have an EWG, which I think they implemented in 2012, then the boost can peak around 14psi.
Rich80766.00
      03-17-2021, 08:55 AM   #10
Rich807
Drives: X2
Thanks. I agree that today it's not a good rule of thumb with the way modern turbo vehicles are designed.
