04-02-2017, 07:14 PM | #1 |
Rep 828
Rusty Hubs?
Changing out my winters for summers today, and I noticed some surface rust on that hub lip that our wheels hang on. I also noticed a little bit of rust inside the hub, which had a little bit of grease remaining. I cleaned both surfaces a bit with paper towel and degreaser, then put a thin layer of new grease on both. Was that sufficient to inhibit rust? Is it Ok for both surfaces to have grease on them?
04-02-2017, 08:54 PM | #3 |
Rep 828
Cool. I guess I could also try some light sandpaper. Thanks!
04-03-2017, 09:17 AM | #4 |
Need mo $$s
830
Rep 882
Clean them up well, then put a small amount of this on the hub surface where the wheels contact the face and also around the outside of the center hub ring where the wheels meet.
A very light coat is all that you need, use very sparingly. Makes the swap of your summers/winters and also removal of any spacers MUCH easier! DO NOT USE ON THE BOLTS!! https://www.amazon.com/Permatex-8007.../dp/B000FW7VGE Enjoy! John
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport |
04-03-2017, 02:04 PM | #5 |
Rep 828
I've actually been using that on lug bolts and spark plugs for years, torqued to spec and haven't had any problems. Why not use on the bolts?
04-03-2017, 04:01 PM | #6 |
Need mo $$s
830
Rep 882
I've just always read to not use it on lugs, but if you've not had any issues then never mind
Try it on your hubs too...
04-03-2017, 05:02 PM | #7 |
Rep 828
I will-thanks.
04-03-2017, 08:09 PM | #8 |
Mporium BMW
3749
Rep 2,907
Drives: 2011 E93 M3
Works great on the hubs. And absolutely use a bit on the wheel bolts too. It'll keep them from rusting also.
