05-14-2021, 12:29 PM | #1 |
6MT FTMFW
61
Rep 229
Drives: 11 E90 335xi E91 6MT 12 X5 35i
Garage List 2005 330ci Vert ZHP [0.00]
2011 335xi Sedan M- ... [0.00] 2011 328xi Wagon M- ... [0.00] 2012 X5 35i M-Sport [0.00] |
Suspension recommendations? 35i Msport
Has anyone replaced their shocks/dampers with OE Sachs parts? I have a 2012 35i Msport with the actual sport suspension (no sport suspension delete). I looked at the B12 kit from Bilstein but I don't really have any interest in lowering the car.
My car has 120k on it, as does the suspension, so I'm just looking to make it ride a bit smoother.
2011 LMB E90 335xi 6MT: Wagner EvoII FMIC, Catless DP, PE Mod, Cobb CP, BMC Filter, ST Coilovers, Strongflex TSB's, Whiteline RSFB Inserts, CDV Delete, Hawk Talon Rotors & PC Pads
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete |
05-14-2021, 01:01 PM | #2 |
Rep 994
How about B6 shocks if available? B6/8/12/14 are all valved the same. But meant for different ride heights.
B6 being for stock height. B8 for lowered cars B12 with matched lowering springs B14 coilovers B4 is stock OE equivalent shocks, should ride like stock
05-14-2021, 04:25 PM | #3 | |
Rep 433
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread https://www.xbimmers.com/forums/show....php?t=1529213 |
05-17-2021, 11:17 AM | #4 |
6MT FTMFW
61
Rep 229
My car has S226A Sport Suspension Settings, as opposed to the normal "sport suspension delete" that you see on most cars. I believe the normal sport package has "sport suspension delete" and the M-sport package will have S226A. RealOEM also shows different part numbers for the shocks with and without S226A.
05-17-2021, 01:29 PM | #5 |
Rep 548
Correct. The sport suspension has different struts/shocks compared to the normal setup. Im pretty sure the springs are the same tho
05-18-2021, 11:04 AM | #6 |
6MT FTMFW
61
Rep 229
It's confusing because for example, the front strut for S226A is 31316781920 and the non-S226A strut is 31326781918, but the SACHS equivalent for both on FCPEuro is Sachs 315-312.
Maybe they aren't that different?
