      04-27-2021, 04:05 PM   #1
yikchandev
Drives: X5
Need new spark plugs
So I need new spark plugs, but heard getting 1 step colder is recommended, since I'm going to be running the racechip RS tune, with a BMS intake. Future mods include downpipe and reinforced chargepipe.
What kind of spark plugs will give me the best performance with the tune? and ignition coils?
2013 x5 xdrive35i e70 w/ Racechip RS and BMS intake.
mhkm13.50
      04-27-2021, 04:33 PM   #2
mitch808
Drives: 2012 X5 35i
It's not about performance. It's about longevity.
Copper < Platinum < Iridium < Ruthenium. My vote is the Iridium as the best middle road in price and performance.
Yes one step colder, also a tightening of the gap a bit more than factory recommended spec.
      04-27-2021, 06:09 PM   #3
yikchandev
Drives: X5
will 2 step colder spark plugs be bad for my car/engine if i revert back to stock? or should I stick with OEM spark plugs for my racechipped n55? I heard oem's can blow up easily with racechip/piggyback tuned engines.
https://burgertuning.com/products/ng...-plug%20%20%20
      04-27-2021, 06:10 PM   #4
darkb0y
☯ like.no.other ☯
darkb0y's Avatar
Ukraine
Drives: BMW X5M E70
You can buy OEM N20 spark for your S63 engine. Don't ask me why. Just trust
      04-27-2021, 06:18 PM   #5
yikchandev
Drives: X5
I have the n55 engine. I was thinking abou the 2 step colders found here: https://burgertuning.com/products/ng...-plug%20%20%20
Will these be bad on a stock motor with no tune in the event i decide to remove my racechip tune?
      04-28-2021, 11:10 PM   #6
pdX5M
pdX5M's Avatar
Drives: E70 X5M
2013 BMW X5 M  [0.00]
That's what I'm running in my Stage 2 X5M with the S63 - gapped to 0.020". Not sure whether you need that in the N55. Gap of the plug is related to boost. Lots of boost can blow out the spark. I'm right around 21psi peak with the tune I have.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
      05-07-2021, 05:40 PM   #7
2012x5x2021
Drives: 2012 x5
just new and i guess i need to do this?
this is a stupid way but i need to post i guess, hello
      05-07-2021, 08:06 PM   #8
titanle
titanle's Avatar
Drives: 2010 X6 Activehybrid
I have mine gapped at 0.020 as well with the ESS tune.
If the tune is removed, would that cause any problems with plugs that are gapped that way and 2 steps colder?
