      10-05-2015, 09:30 AM   #1
LastLong
LastLong's Avatar
Drives: Nothing
Question for Winter
Hi guys,
I would like to know for this winter...
1) do you keep your spacer for winter or should I remove them?
2) summer tires I have 275/40/20 front and 315/35/20 rear.... and winter tires should I got 275/40/20 all around or ...
Thank you !
- 2015 F85 BMW X5M = SOLD
- 2012 E70 BMW X5 35i - M Sport = SOLD
- 2008 E71 BMW X6 35i - Sport Pack = SOLD
- 2007 E70 BMW X5 4.8i - Sport Pack = SOLD
- 2007 E70 BMW X5 30si - Sport Pack = SOLD
      10-06-2015, 08:42 AM   #2
PAX5
Drives: 2012 X5 50i
Are you using an extra set of wheels? What size, width?
      10-06-2015, 12:21 PM   #3
LastLong
LastLong's Avatar
Drives: Nothing
I use OEM 20" style 214 wheels for Winter.
      10-06-2015, 07:52 PM   #4
PAX5
Drives: 2012 X5 50i
The BMW Style 214 are staggered and a full inch wider in the rear. You will have to look carefully at the spec of 275/40-20 tire you select to see if they can be mounted on an 11 inch wide wheel. It would also look "awkward", the tire may look stretched ...
A better strategy would be to find another set of wheels from an e70, like a non staggered size 18 or 19. You can even look at the the X5 e53 series for wheels ... They'll be cheap, but you'll have to bore out the center bore to 74.1mm for it to fit the e70.
PAX5
BMWCCA 20645
      10-07-2015, 11:56 AM   #5
LastLong
LastLong's Avatar
Drives: Nothing
Yeah I understand, but I would like to keep my stock style 214 for winter :P
What about spacer? Its okay if I keep them for winter? Somebody remove them for winter or....
      10-07-2015, 12:05 PM   #6
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
I have the exact same setup you're discussing. I have a second set of replica 214s with 275/40/20 all around. It does look stretched in the rear, but the technician said there's no problem. I checked out the specs for Scorpions on the Tire Rack website, and the staggered rears were just slightly out of spec for the 275s. I already went through one full winter with them, and they worked great. While I would prefer 315 in the rear to be well within spec and keep the stock appearance, the 275s worked just fine. Winter's an ugly time anyway. You just need to be careful about potential curb rash.
      10-08-2015, 01:16 AM   #7
theaudir8fan
theaudir8fan's Avatar
Drives: a major headache
Yes it is ok to use spacers during the winter, my advise is to just anti-seize the hub and the spacers. however consider how much crap is on the road, why do u want the stance only to throw up rocks and etc which causes paint damages on ur own car
      10-08-2015, 11:49 AM   #8
sergeny1
sergeny1's Avatar
14
Drives: 2021 X4C
Let's get bit more specific - If you leave in Northeastern United States would you keep spacers or not ...> ?
I plan to keep my on the car for this winter. ( Live in NYC )
      10-08-2015, 01:01 PM   #9
ideliver
ideliver's Avatar
240
Drives: E60 M5, E71 X6M, E46 M3
2006 BMW E46 M3 'vert  [0.00]
2008 BMW M5  [0.00]
2011 BMW E92  [0.00]
2012 BMW X6M  [0.00]
2003 E46 M3  [0.00]
no...given a proper offset
Current: 2006 E46 M3 'vert 6-sp 2008 E60 M5, 2011 E92 328 6-sp, 2011 E70 N55, 2012 E71 X6M
      10-08-2015, 06:37 PM   #10
theaudir8fan
if u want to do it, go for it, there aren't any technical issues that would arise from using a spacer in winter
      10-13-2015, 10:58 AM   #11
LastLong
LastLong's Avatar
Drives: Nothing
Thank you all guys!
