01-06-2021, 01:14 PM | #1 |
Rep 9
HELP, E70 JBE issue after disconnecting!!
Hello, new to this forum as a registered member but have used it for countless BMW's issues the past 5 years.
I recently disconnected the JBE's blue connector and pulled all of the fuses out of the JBE while trying to check for a burnt fuse. I did all of this without disconnecting the battery. After all the fuses were back in and i reconnected the JBE's blue connector i started the car and my windshield wipers would not turn off, the ASC, DSC 4x4 warning came on and the speedometer stopped working. i used my autel maxidiag to read codes and try to delete them but none of them would go away. most all of the codes read no message. I have tried hard resetting the the car by touching the positive and negative battery cables together with no luck. I have also tried deleting all of the pending codes with no luck. I am curious if i need to flash the modules or if there is something else i need to do. Any advice would be greatly appreciated. Airbag-ACSM Crash Safety Module -------------------------------------------------- 9415 - No message from DSC control unit, ACSM receiver / MRS5, DSC transmitter 9414 - No message from DSC control unit, ACSM receiver / MRS5, DSC transmitter 93FB - No message (vehicle speed) from DSC, ACSM receiver / MRS5, DSC transmitter FRM2 Footwell module 2 --------------------------------------- E59A - No Message (yaw rate) receiver FRM, Transmitter DSC E599 - No message (driving speed) receiver FRM, transmitter DSC E597 - No message from DSC control unit, receiver FRM, transmitter DSC E594 - No message (steering angle), receiver FRM transmitter IHKA intergrated automatic heating/air conditioning --------------------------------------------------------------------- E71C - No message (speed, 0x1A0), receiver IHKA transmitter DSC E721 - No message (failure of HDC display, 0x32D), receiver IHKA transmitter DSC E729 - No message (automatic air recirculation control sensor, 0x2D0) receiver integrated automatic heating / air conditioning system, transmitter JBE INSTR Instrument cluster ----------------------------------- A3AC - No message (distance travelled, 0x1A6) receiver Kombi, transmitter DSC A3B9 - No message (dynamic stability control 0x19E) receiver Kombi, transmitter DSC A550 - No message (speed, 0x1A0) receiver Kombi, transmitter DSC A556 - No message (HDC display) receiver Kombi, transmitter DSC JBE2 Junction box electronics ----------------------------------------- C918 - No Message (wiper operation, 0x2A6), receiver JBE, transmitter FRM/SZL/LWS/IHKA A6CA - JBE: Closing relay, windscreen wiper A6C9 - JBE: windscreen wiper EGS 6HPTU transmission control -------------------------------------------- CF34 - Message from the DSC, Receiver EGS, transmitter DSC CF2B - No Message from longitudinal dynamics management, receiver EGS transmitter GWS/LDM |
01-09-2021, 06:48 PM | #3 |
Rep 1
No Start on my 2007 x5 3.si after replacing batterie
Hello ,
my 2007 x5 3.0si will not start or crank after I replaced the battery and did oil change. car was park for almost 2 years. Any Idea? I switched coils, did oil change, replaced coils, replaced battery and now there is power when put key in the slot but nothing else. Car will not crank over. Please help.. Thanks, |
