11-28-2019, 03:10 PM | #1 |
Rep 19
Happy thanksgiving! Now I really need some help... egr cooler bolt broke
Hello...
Once again I got stuck doing a DIY... at some point I should realize that those are not for me and I better leave it to the pros... anyhow, long weekend and I tried to replace the egr cooler which had a broken spring. Doing so I ended up snapping one of the bolts, see picture. I think it happened due to the bolt not having a clean thread but rather grease and dirt in it... this came to me after the fact... it was really hard to extract and then snapped... From comparing the bolt length to the new ones I know I do not have much stuck inside, see image. Now to my questions... how do I get this fixed? I guess I would need to get it drilled out. I have never done this and the spot is tight with nearly no viability. Anything I can take off to gain more room? I believe that I will not be able to use an extractor Since my believe is the rest of the bolt is stuck due to dirt in the threads. Let me add... it’s a e70 Diesel Thank you! Last edited by Tractorguy77; 11-28-2019 at 03:15 PM.. |
11-29-2019, 10:07 PM | #2 | |
Rep 3
11-30-2019, 02:01 PM | #5 |
Rep 19
I like the idea of popping it out in the back... drilling necessary or can it be pushed out somehow? I assume you would use a right handed drill bit to drill/force it to pop out in the back, or?
12-01-2019, 08:52 AM | #6 |
Rep 41
It's such a small piece that just drilling or tapping on it might knock it out. They sell reverse thread drills bits but until you get in there and try it's pure it's just guess work on what method would be easiest. There isn't very much room to do anything but I think it would help a lot if you removed the rad.
12-01-2019, 07:23 PM | #7 |
Rep 1,054
Okay so you broke the bolt on the exhaust side of the egr connection? And broke the bolt off at the end maybe 3-4 threads in? Why not cut the bolt down to the good threads and tighten in?
You still have plenty of thread to hold it in. Maybe while you're at it install and egr race pipe, block off the coolant lines, and zip tie the egr valve off to the side and be done with it forever.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
12-02-2019, 07:51 AM | #8 |
Rep 1,157
Believe it or not I was able to connect the pipe up with one bolt as a temporary install when I had that same bolt break. No leakage, no smells. I kept procrastinating the repair until that vehicle was written off.
12-08-2022, 12:22 AM | #9 | |
Rep 15
Here's what I did: Used a right angle drill and cobalt drill bits to drill the titanium piece out. Once I could see the 'threads' starting to show, I used a small flat head to start picking at the remaining threads inside the hole. Once all out I re-tapped the hole and voila! I only broke one bit ... but the process did end up taking 4 hrs or so of very slow drilling. |
