F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW F32 iStufe Update Fail ECUs no Respone (solved)
Studio RSR
      03-20-2024, 09:51 PM   #1
mert95
Drives: BMW 430D F32
Hello from Germany
My Name is Mert and i own a F32 430d.
2 days ago i made a Software Update with Ista 4.39.20 with Psdzdata 4.39.20 and during the Update my car died because of a Power Supply failure .... (thats my fault it was too weak ).
Now i got a bigger Power Supply and charged the car... and its enough for Ista and Esys
Now the car starts and shifts but the Kombi, Nbt_evo and Tv_Modul are dead..
Nbt boots up and stucks on the "Flashing Time" Blue Screen but the Kombi is Lighting Up and working it only has the red dot.
I tried to flash it but the ECUs are not responsing.
If i read ECU instead of VCM the 3 ECUs are not in the SVT.
I tried today all day to repair it.
I tried injectin CAFD and i get a faulty code.
Can somebody help me?
      03-21-2024, 06:07 AM   #2
Siki78
Siki78's Avatar
136
Drives: F30,G30
Can be flashed with esys just diese 3 ecu. If you need help, I can
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      03-21-2024, 06:11 AM   #3
mert95
I tried several times with esys but the 3 ecus give no response
Thank you
      03-21-2024, 07:24 AM   #4
Siki78
Siki78's Avatar
136
Drives: F30,G30
I write you pm give me teamviewer on same
      03-21-2024, 09:12 PM   #5
mert95
Thank you very much Siki78
For all other if you have something like that here you can see how it got solved
      03-22-2024, 02:49 AM   #6
Siki78
Siki78's Avatar
136
Drives: F30,G30
It was little bit more complicated than just flashed. Navigation was stuck in bootloader mode so if you look with esys no responding from HU,kombi and TV module. First we get out from bootloader mode then was easier to flash ibad and swfl. You picture is wrong because blue is actual target should to be with 000 and red are update file
mert951.50
fe7565552.50
      03-22-2024, 11:35 AM   #7
mig2830
Drives: F30 340I
Most interesting. Siki78 How do you get out of Bootloader mode?
      03-22-2024, 12:13 PM   #8
Siki78
Siki78's Avatar
136
Drives: F30,G30
First you need to flash just bootloader with esys 3.27.1 other esys will not work.
mig283039.00
      03-22-2024, 03:34 PM   #9
Revoltos
Revoltos's Avatar
53
Drives: BMW F30 335i
Siki78, what a decent guy you are. Stepping into help immediately. Kudos to you mate!
Siki78136.00
mert951.50
      03-22-2024, 08:33 PM   #10
mert95
He is my hero im so thankfull i cant describe that feeling that car bootet up again
Siki78136.00
f30post
