03-19-2024, 02:15 PM | #1 |
Rep 31
How to prevent car to turn off ignition
Hello, how can I prevent my car to turn off ignition after some period of time?
I dont feel safe to code anything, when I know that it can turn off anytime. Is there any way to prevent it? |
03-19-2024, 02:39 PM | #2 |
Rep 1,127
hey Happy Hippo.
If you are using some app store software like bimmercode or carly to code options on and off, first that is relatively safe as you aren't flashing any ECU with software just upload config files. Second your software should be making a backup for the stock setting before you alter anything by default. Given those two details I keep the car running while I am coding it, with the exception of the DME (engine ECU). Are you asking how you can keep your finger from hitting the start/stop button while coding and turning the engine off? There is no method to accomplish that I have heard off. |
happyhippo4.50 |
03-19-2024, 04:23 PM | #3 |
Rep 1,582
Keep the light in parking mode and fasten in the driver's seatbelt.
Do not code DME while care running...as zinner said.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
happyhippo4.50 |
03-19-2024, 04:56 PM | #4 |
Rep 16,094
My car has never turned off while using Bimmercode, until Bimmercode shut it off when it was done.
happyhippo4.50 |
03-20-2024, 01:19 PM | #5 |
Rep 31
03-20-2024, 01:21 PM | #6 |
Rep 1,582
Turn the light switch into parking mode.
