09-02-2014, 07:11 PM | #1 |
Rep 119
Coding error. CAFD not found
I got my car back from the dealer today and was trying to code FEM_BODY and REM and I got these errors:
REM [72] [FX59659] readCPS o.k. CAFD_000007A1_005_034_007 Fehler: File for "cafd_000007a1-005_034_007" not found! [C012] FEM_BODY [40] [FX59659] readCPS o.k. CAFD_00000794_012_034_013 Fehler: File for "cafd_00000794-012_034_013" not found! [C012] Does anyone know what this mean? Thanks |
09-03-2014, 08:46 PM | #6 | |
Rep 40,810
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
10-21-2014, 06:13 AM | #8 |
Rep 2
hi ,
I have take the same error and I sent the PM to shawn. Transaktions-Report: Aktion: Codierdaten lesen FEM_BODY [40] [F892703] readCPS o.k. CAFD_00000794_012_034_013 Fehler: File for "cafd_00000794-012_034_013" not found! [C012] |
10-21-2014, 06:16 AM | #9 |
Rep 40,810
I have replied to your PM.
12-01-2014, 11:16 PM | #11 |
Rep 3
Could I get in on that too (get the latest 54 lite version)? I just got my 328 back from the dealer and cannot code FEM_BODY and some others. I downloaded 53.4 lite, but it didn't help. The only useful one left that I can write to is HU_CIC.
12-02-2014, 12:27 AM | #12 |
Rep 40,810
PM sent.
12-05-2014, 08:46 PM | #13 |
Rep 3
I think we still have to wait for newer because FEM_BODY is still not working. BMW must have a newer version. I also noticed once my car was updated by them that the car no longer allows auto-shut off of the engine if in Sport mode. I might have to look into re-coding that I am happy to get a new version of E-sys with a token. Thanks shawnsheridan.
12-06-2014, 07:18 AM | #14 | |
Rep 40,810
FEM_BODY - cafd_00000794.caf.012_035_116 HU_NBT - cafd_00000ded.caf.003_013_024 Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from above => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. Afterwards you will be able to FDL Code ECU.
kern4174449.50 |
12-06-2014, 07:06 PM | #15 | |
Rep 2,047
2023 G21 M340i LCI
Previous - 2020 G21 330d M-Sport, F31 335d M-Sport, F31 330d M-Sport |
12-06-2014, 08:07 PM | #16 |
Rep 40,810
12-06-2014, 08:48 PM | #17 |
Rep 20
Hmm... Actually i try to understand all these things, so sorry for the question: For what are these CAFDs files good for? Is this the firmware of the ECU?
If i VO code my ECU to a lower version of CAFD, is this a software-downgrade then? |
12-06-2014, 09:08 PM | #18 |
Rep 40,810
CAFD is a Coding Application File Data, not firmware, and it is downgrading nothing.
02-16-2015, 09:50 AM | #19 |
Rep 4
I get the following errors when I try to VO code HU_NBT and FEM_BODY using PSdZData 54.1
File for "CAFD_00000794-012_035_117" not found! (C012) File for "CAFD_00000ded-003_013_025" not found! (C012) I just picked my 435i GP from the dealer about a week ago so I bet it has already a newer software installed. I am trying to activate 6NS and the Active High Bean Assistant. Any thoughts of what might be the problem? Do I have to use a newer PSdZData to FA/VO code. Thanks. |
02-16-2015, 09:51 AM | #20 | |
Rep 40,810
http://www.bimmerfest.com/forums/sho...2&postcount=12
11-14-2015, 12:30 PM | #22 |
Rep 5
Hi,
I installed a NBT and want to code it, but get the following error: cafd_00000ded-003_013_033 is missing I am using the PSdZData 57.0 Does anyone else have this problem? Where could I get this file? Thanks |
