      11-30-2013, 06:02 PM   #1
Joyaant911
Drives: 2007 x5
Aftermarket control arm
So mines are due for changing BMW wants crazy money. I know ppl have used aftermarket here... My question is what namebrand did you use or what aftermarket namebrand is good for control arms??
      12-01-2013, 06:43 PM   #2
zsx_m
Rasp Addict
zsx_m's Avatar
97
Drives: Moonstone M4
I have used the kit from fcp groton/fcp euro, according to my shop they suck, but they get the job done and are cheap..
      11-28-2015, 01:31 PM   #3
Da M3nace
Da M3nace's Avatar
25
Drives: 04 M3
Just put on a pair of Mayle arms. $200 for the set and work and fit perfectly.
      11-28-2015, 04:31 PM   #4
smyles
Drives: '21 X5
Go with OEM. I'm all in favor of using aftermarket parts, etc., but history and other people experiences show non-original control arms don't last long.
      11-28-2015, 05:04 PM   #5
socale39
Drives: 04 545i SMG
Lemforder or Meyle HD. Anything else and you be back replacing the part sooner than expected.
      11-28-2015, 05:44 PM   #6
smyles
Drives: '21 X5
What kind of experience with Lemforder or Meyle control arms for E70 do you have to make this kind of recommendation?
Thought so.
      11-28-2015, 07:52 PM   #7
socale39
Drives: 04 545i SMG
Rebuilt my E46 and M5s with these parts and never had a problem. I actually just ordered up Lemforder sway links for the E70 today. Lemforder is OEM. Standard Meyle parts are ok but their HD line for control arms and bushings are improved over stock and in my experience have been excellent in keeping things tight.
      11-28-2015, 09:38 PM   #8
smyles
Drives: '21 X5
So none.
      11-28-2015, 10:03 PM   #9
socale39
Drives: 04 545i SMG
Anyways, OP, there's no reason to buy OEM Genuine BMW parts when you can literally buy the exact same part for nearly half the cost just without the BMW name or box. Much Like Textar and Pagid are brands that BMW uses for their brake pads. Just do your research.
If you know take the last 7 of your vin and punch it into www.realoem.com it will give you the parts breakdown and from there you can determine the correct corresponding part# you need.
