      12-01-2015, 03:19 AM   #1
Dchl21
Drives: x5m / E55 / C63
with 22s with these offsets fit nicely ?!?
Bolt Pattern is 5x120, 9.5 in the front +32 offset and 10.5 in the rear +35 offset
for e70 x5m
would it fit nicely ? or need spacers to sit flush on a lowered x5m
thank you in advance wheel gurus
      12-01-2015, 03:57 AM   #2
theaudir8fan
theaudir8fan's Avatar
Drives: a major headache
will need spacers if you want them flush
      12-01-2015, 07:39 AM   #3
socale39
Drives: 04 545i SMG
Those widths are a bit narrow for that application.
      12-01-2015, 07:42 AM   #4
gixxerboy63
Tanzanite Blue II X5M Pilot
gixxerboy63's Avatar
1047
Drives: M3, M4, X3 M40i, X5M
2017 m4  [0.00]
2010 BMW X5M  [10.00]
Spacers can make them flush, but I still think they are too narrow for an X5 (especially an X5M). As a comparison, our OEM wheels are 20x10 front and 20x11 rears. My BBS SVs are a full inch wider on both ends. The reason that the wheels you are looking at are narrower is likely because they are not TUV rated or strong enough for use on heavier vehicles.
2020 X5M - Tanzanite II
2012 M3 - Alpine White
      12-01-2015, 09:44 AM   #5
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
I have similar offsets and run 22x12 rear 22x10 fronts and also run 12mm spacers to be fully flush. You're going to need a lot of spacer.
      12-01-2015, 03:00 PM   #6
Dchl21
ok .. no go ... ill keep looking. thanks bros !
