F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Car not rolling on small slope
Studio RSR
      03-27-2024, 07:46 PM   #1
Ageispolis
Drives: 2011 E92 335xi
I park in a spot with a very subtle slope. When I had an e92 it used to roll out whenever I let the clutch down. Now in my f30, it just sits there. I checked the wheels and they spin freely. Any idea what this could be?
      03-27-2024, 08:22 PM   #2
SpoolinAddict
Drives: 2015 F30 335i Stage 2 BM3
I had a older car without hill assist, and I would use the E-brake method on hills. I don't have MT f30 but maybe you have hill assist turned on? most newer gen cars should have it
      03-27-2024, 08:41 PM   #3
DreamerJoe
Drives: 2017 340i M.G. w red interior
I had a manual F30 and the hill assist will hold the car for you for a fee seconds until you take off. Not sure if you can disable or code it out. Also had to get used to not being able to blip the throttle and feather the clutch when parking, reversing, and doing slow maneuvers. There are a few things they do to assist you, but I would have rather not had.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
      03-27-2024, 09:58 PM   #4
wishbone
///M
wishbone's Avatar
Drives: '18 F80 M3 ZCP, '14 F30 328i
2014 BMW 328i  [0.00]
2018 BMW M3 ZCP  [9.00]
Yes this is the same for my f30 and f80 MTs.
      03-28-2024, 09:46 PM   #5
Ageispolis
Thanks for the replies. So I guess it is hill assist? Anyone know how to test that by turning it off?
      03-31-2024, 01:10 PM   #6
pshovest
BMW CCA 69606
86
Drives: '15 435i,'10 535i,'08 X5,'98M3
I don't know how to turn it off, maybe there is an iDrive setting.
My 6MT 435i will release ~2 sec after taking foot off of brake.
Does car roll if you stop on a steeper incline and release brake?
      03-31-2024, 03:03 PM   #7
toxik
toxik's Avatar
Drives: 2017 340i xDrive 6MT
do it in neutral, hill assist only works if you’re in gear
      04-01-2024, 05:23 AM   #8
Nachos23
HotBimmer
Nachos23's Avatar
Drives: 2016 335GT & 2000 Z3M Roadster
2016 BMW 335GT  [0.00]
2000 BMW Z3M  [0.00]
in my older e36, which is manual, I don't need brake while on small inclines as well. I beleive it was in the the bearing assembly, but can't recall exactly, but BMW has some small "fins" (not sure what to call them) that assist with reducing backwards roll on slight hills; I was also curious because of same reason ...
if you can, jack up one front wheel and try spinning replicating forward and reverse movement and see if it spins as easily in both directions...should be slightly stiffer to spin in reverse... be interested if you feel it?
my f34 and old e90 were both auto, so foot always on brake when stopped or neutral on inclines..
2016 335GT & 2000 Z3 M Roadster
      04-01-2024, 06:05 PM   #9
Wires
Drives: 2016 340i xDrive
I thought the Fxx series had a deal that you didn't need to hold the brake in neutral (car did it for you) to assist in starting out on slopes? The automatic manual!
f30post
